charging battery questions lipo
  • okieman98
    • Jan 2014
    • 229
    i got this charger
    http://www.amainhobbies.com/product_...FWoS7AodrDkA8A
    and trying to charge for the first time but not sure what to set it at. charging 2s 5000 30 to 70c
    what amp should i set it at. it got .5 to 5 amp. have it set to lipo that i did get. instruction not very clear
    thanks all
    1 motley crew- under construction 2x shock wave 26-2 x surge crushers - 1 30' mono
  • okieman98
    • Jan 2014
    • 229
    anyone have one of these and can tell me how it charges , and acts so i know if it is working rite
    • TheShaddix
      • Sep 2013
      • 759
      Set it to 5 amps. Change the cell count to 2s also.
      • okieman98
        • Jan 2014
        • 229
        ok thanks
        • okieman98
          • Jan 2014
          • 229
          i know i new but still trying to get this all going . when charging lipo do u just plug in the balance plug and the set to charge are do u use the banana plug to the battery that has deans plugs are plug in both.
          also i got a shockwave 26 bl. it call for a 3 s lipo but not sure what to get to make this boat run well and not burn it up. i want it to preform well. i have Capacity: 5000mAh
          Voltage: 2S1P / 2S Cell / 7.4V
          Discharge: 35C Constant / 70C Burst. but wanting to get some 3 s for this boat. will the 2 s work i have. and what 3 s battery's to get for this. i was just going to start with some Turnigy are something like that. till i get better . i just dont know how to match up with the 20 are 30 c and miliamps and so on.
          thanks everyone for the help
          • danielplace1962
            • 91
            Plug the balance to the balance port and the discharge lead to the chargers bananas. Set for LIPo BALANCE CHARGE, 5 amps and 2 cells (2S) for the first battery you asked about.
            The more the C rating the higher the load it will take without damaging the pack. The milliamp hour (mah) is the capacity. The higher the longer it will run a load.
            • okieman98
              • Jan 2014
              • 229
              ok thank u very much
