Storing My Hyperion problem
  • dasboata
    • Dec 2010
    • 3972
    I am try to put this battery in storage mode. I can not do it it is a split wired battery I tryed do it on all 6 cells that does not work I then tried doing 4 cells and that did work with the balancer,, but when I tried the 2 cell it said open circuit the balancer jack only fits in the 4S slot any help is appreciated thanks chris
    Not to be a pain but, why the heck would they do that? What purpose does it serve to have a split pack as such?
    Are you plugging directly into a HXT receptacle with those Hyperion connectors? I ask because I think they are a different layout than the more common HXT connectors.
    When you say "it wouldn't work" what actually happened?
      It's possible one of the balance leads for the 2S pack has disconnected.
      • pugman2
        • 241
        never seen anything like this before
        • longballlumber
          • 3417
          It looks like that pack is a 2s and 4s pack shrinked together with separate power leads and separate balancing taps.
          When you tried charging as 2s and/or 4s did you use the appropriate power leads? In the pictures you still have the batter connected as a 6S pack
          Later
          Mike
          • rickwess
            • Apr 2013
            • 777
            The pack is essentially a 4s and 2s cell bundled together. ThunderPower does that as well for their 6s packs. When charging, you will need to treat them as 2 separate packs by disconnecting the pig-tails between them.
            • dasboata
              • Dec 2010
              • 3972
              They do that because of some law about shipping Lipo's yea I know it is a PITA
              • dasboata
                • Dec 2010
                • 3972
                Later
                Mike
                Yes of coarse I tried all the ways
                I did do that of coars thanks guys , I am going to send it to Doug S and have him take a look at them ,, don't tell him yet LOL
                  Do you connect the balance leads first? Have you possibly plugged the power leads in first on the pack that has a bad reading?
                  Mike Pags had me send my pacs to a guy in the USA for a reconfiguration and he does pro work but, if Doug is up to the task let him try it out. I actually run 6S in 2S+4S configuration now so I can use the cells in other boats.
                  • dasboata
                    • Dec 2010
                    • 3972
                    No with the hyperion charger they suggest you plug the power leads in 1st. I already blew one up ??
                    • RaceMechaniX
                      • 3024
                      Chris,
                      For the split packs, Hyperion sells or sold a split balancing connector. Some were for 3S + 3S and later ones were for 4S + 2S. You connected the balance Y up first, connected the intermediate bullet and then plugged the battery into the charger as a single 6S pack. My Hyperion 6S packs came with the special balance harness.
                      TG
                      Tyler Garrard
                      NAMBA 639/IMPBA 20525
                      T-Hydro @ 142.94mph former WR
                      • dasboata
                        • Dec 2010
                        • 3972
                        Chris,
                        For the split packs, Hyperion sells or sold a split balancing connector. Some were for 3S + 3S and later ones were for 4S + 2S. You connected the balance Y up first, connected the intermediate bullet and then plugged the battery into the charger as a single 6S pack. My Hyperion 6S packs came with the special balance harness. I will try that I might have the harness downstairs and I will plug it in 1st thanks man Chris
                        TG
                        I might need Miks help thank you
                        • dasboata
                          • Dec 2010
                          • 3972
                          Chris,
                          TG
                          Tyler is this the connector you are talking about ?
                          • kevinlew211
                            • 706
                            what you can do is turning those balance wires to 6s1p by connecting the positive (red) balance wire of 2s to positive (red) of 4s connector and taking of 2 of negative balance (black) wires from 2s and putting them into the next 2 slot of your 4s balance connector, its simple easy and you dont have to deal with with 2s1p +4s1p balancing again.
                            • RaceMechaniX
                              • 3024
                              No Chris, it's a simple Y harness without the PCB board. Don't have a picture handy and did not see one online.
                              Tyler
                              Tyler Garrard
