C question
  • jetskier
    • Jan 2013
    • 230
    C question
    I have a Motley Crue and lots of 4S batteries for my Revolt, my question is if I run two 4S 30C 4200mAh in parallel in my MC will I have 60C and increase my run time?
  • jfrancisco892
    • Feb 2012
    • 546
    C rating is a coefficient to calculate constant available discharge rate. If you ran 2 4s batteries in parallel you would have a total capacity of 8400 mah or 8.4 amp hours. To calculate maximum constant discharge rate take total capacity in amp hours (8.4 in your case) and multiply it by the c rating of the cells (30). This gives you a constant discharge rate of 252 amps. An important note: c ratings are not always completely accurate and are more commonly used as a relative figure between batteries to distinguish quality. However, in your case I'm assuming you are talking about the grim racer batteries which I have found in my experience to have a true c rating and if any ambiguity exists I would say they may be slightly underrated.
    As for run time the increase in capacity will increase run time as c rating shouldn't play a factor in that regard.
    Hope this helps,
    Jimmy
    • NativePaul
      Greased Weasel
      • 2764
      You will still have 30C, but you will double the current your battery can put out as would now be capable of 30 x 8.4Ah = 252A as opposed to 30 x 4.2Ah = 126A, you will increase your runtime.
      • jetskier
        • Jan 2013
        • 230
        cool!! thanks guys, understand clearly now.
