ESC wiring opinion
  • kacordy
    • Oct 2012
    • 410
    ESC wiring opinion
    Please look at this wiring set-up on this Hydra 120. It's very interesting. I have always used Deans off my ESC and then used the y connection to create 4s. This set-up appears to eliminate the Harness. I bought 50 5.5 and will start converting everything over.
    Is the picture below OK and Superior.
    Thanks for the feedback.
    Allen
  • Chilli
    • 3067
    That looks to be a parallel adapter on the left to run 2s2p (if you are using two 2s packs). To run two 2S packs in series to make 4S, no need for an adapter when using bullets. You simply plug the positive side of one battery to the negative side of the other. Then plug the remaining bullets into the ESC.
    Mike Chirillo
    www.capitolrcmodelboats.com
    • kacordy
      • Oct 2012
      • 410
      Chilli,
      Got it. Never thought it through and that makes it easy. Appreciate the advice. I'm slowly learning this stuff. I just want to have fun!
      Allen
