Fighercat Cheetah 6s2p
  • tiqueman
    • Jul 2009
    • 5866
    Started filling. Will try and have it done for this weekends club test n tune
    • sampit
      • Jul 2009
      • 466
      Great news, keep us updated on the results, looking forward to this one
      Anyone thinking about buying a Cheetah dont be put off by any of this is its a fantastic handling hull anyway, just might get even better with a little extra work.
      FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
      Popeye Hydro T600 1400kv 6s1p
        • tiqueman
          • Jul 2009
          • 5866
          Yes the cheetah is one of my favorite hulls....and I have a lot of boats. Those looking at getting one, don't hesitate
          • tiqueman
            • Jul 2009
            • 5866
            #35
            Just about done for a "quicki" Ill shoot it w/ paint today and get it in the water Sunday and report back.
            • properchopper
              rcgoatbuild@snotmail.com
              • 7708
              #36
              I know I promised to not post anymore about this stuff, but here's some interesting info on the theory of stepped hulls posted by Mr. Outcast on another forum. It is in reference to full-sized boats and as such doesn't always translate perfectly to scale stuff, but :
              Stepped%2520Hulls-%2520Feb07[1].txt
              For no particular reason, I'll quote the late British scientist J.B.S. Haldane's take on theory acceptance :
              " Theories have FOUR stages of acceptance -
              1. This is worthless nonsence
              2. This is an interesting but perverse point of view
              3. This is true but quite unimportant
              4. I always said so
              • monojeff
                • Nov 2010
                • 2728
                #37
                To me it seams the last ride pad is stepped down because when on plane there is less area touching the water so it seams as though they wanted to keep as much of the ride pad off the water as possible to keep the least amount of drag possible.
                Instead of showing the ruler flat on the step you should show it at ride attitude where the waterline would be see where that puts things.
                Picture water coming over the last 2 steps you would want both to barely touch the water instead of just 1 to give it a little larger foot print is my take.
                You would also not want the last step to be completely touching and dragging which is what I think would happen if it were the same plane ad the 2nd step.....
                So its kinda like a recovery pad of sorts......
                Then when you come off plane the boat would be on 2 steps instead of just the 1 and when not on plane the boat tilts back on the last pad to help it get on step.
                When at full tilt almost nothing is touching the water just like hydros so its the times when you slow down or turn that really makes a boat look fast if it handles well during these times when running.
                Then again I am still learning!!
                If only we knew who designed the boat we could ask them!
                OSE GIFTING ELF
                HAPPY HOLIDAYS!!
                • tiqueman
                  • Jul 2009
                  • 5866
                  #38
                  At ride attitude it would be severly negative, which is what it is, which is why my boat keeps going under water at 50+ mph.. No worries. Im gunna prove my point in 48 hours. Ill bet all my boats on it. No way that the last ride surface can be that negative compared to the other two and not have a bow down effect. Its acting EXACTLY how what tony posted is explained as a trim tab, angling down. Its extremely simple physics. If it was to lessen the surface area on the last pad, they should have made the indentation of the step two inches longer and keep the ride pad "level" or at ride attitude. It doessnt matter where ride attitude is. it attitude is whatever the hull is telling it to do? If the last wetted surface is at a negative or down angle, its going to put the bow down. For ALL of you non believers, change the trim tab on a mono. Lastly when the manufacturere agrees they messed up..... nuff said So yes Jeff, we DO nkow who made it and I have discussed it with them..... 7 weeks ago.
                  • properchopper
                    • 7708
                    #39
                    (ignore the subtitles - it's actually a sponson-designing think session)
                    • tiqueman
                      • Jul 2009
                      • 5866
                      #40
                      And cats arent made to run like 3 point hydros. If that was the case, why are all the best running stepped cat hulls, be it some only in a straight line, Geico, HOTR, Rivercat, EKOS, HPR, Genesis etc etc.. NONE have the last step 3 degrees negative than the others. NONE
                      • tiqueman
                        • Jul 2009
                        • 5866
                        #41
                        Im done watching and reading. Ill be back after I run mine and thatll be the end of it. This is a waste of time. I have things Ive got to do. I need to call seastar, teleflex etc and tell them to stop making trim tabs... negative angles dont effect bow ride.....
                        • monojeff
                          • Nov 2010
                          • 2728
                          #42
                          I have hardly even looked at the bottom of the boat aside from pics on here.
                          To me it seams the straight edge is not touching the last step??
                          Just don't see how if it is lower then the other step then it would raise the bow not cause it to drop??
                          Maybe I am seeing it wrong.
                          Raise your strut bow up lower your strut bow down....?
                          OSE GIFTING ELF
                          HAPPY HOLIDAYS!!
                          • tiqueman
                            • Jul 2009
                            • 5866
                            #43
                            To catch you up jeff. Im not doing it to try and make the bow ride high because i want it to float more. Im doing it because the boat plows like a tug boat. Like a .. here come the broken record, mono with the trim tabs way down. Its literally pushing the transom out of the water, which in all my years of boating, forces the bow down. Yes, there are ways around it, adjusting this and that to get around hull running issues, but you cant just raise the strut on a twin drive. at least, not easily All I did was match the ride surface of the last step to that of the one before, which matched the front sponson coming into the forward most step. im not trying to re-invent the wheel.. just fixing a flat.
                            the "before' pis, I had a 3' construction angle on it and it was way past the teatering edge of the bottom profile so it was leaning slightly nose heavy if you will. if I push it down it would only touch the very rear of the boat while against the sponson coming in and forward most steps.... If that makes sense.
                            • RCKong
                              • Sep 2009
                              • 1680
                              #44
                              I've been following this 6s cheetah thread ( I have one) and I agree the angle on the last step is acting like a trim tab. I would imagine it creates a bit of drag too. I was amazed to see what it took to air this boat out good. In my twin I had to trim the drives three times to get it to lift the nose, twice the angle of several other boats I have, and it still rides very flat. I kinda wonder if they thought they would be getting more air under the last step...
                              hard to say, but IMO it pulls the nose down - common sense.
                              • tiqueman
                                • Jul 2009
                                • 5866
                                #45
                                Jeff, heres a little more clarification of the, what I see, as a small issue. I just took pics of a hull I havent built yet. First pic is the forward most step surface. 2nd is the last step. In theory, no matter where water hits that last step, because of its down angle and its different more negative angle than the stp before, its going to act as a tab, because, no matter where water hits it being its the last thing water touches when leaving the ride surface of that hull, its being deflected down, which pushes the nose...........
