Ec-5 connector assembly question??
  • homer49
    • 6
    I just got 12 pairs of new blue EC-5 connectors to replace the 4MM bullet connectors I have been using. I am planning to get an I-charger with a paralell charging board soon, but for now I need to know which body do I use for the battery leads - Large outer or small inner, and which metal connectors - male or female in which body? I don't want to get a paraboard and find out I put them on wrong and have to start over??? Blind Squirrel Bob
  • bdp1174
    • 146
    Female with smaller outer plastic on batteries and male on charge leads with bigger plastics.
    • siberianhusky
      • Dec 2009
      • 2206
      Learn from my earlier mistakes and don't go with EC-5 connectors, they are not all they are cracked up to be, go with 5.5 or 6mm bullets. There are many, many issues with ec-5, including the need for extra adapters to connect a pair of packs in series.
      I ended up swapping all of mine over shortly after I began using them.
      The AM-1005 bullets from HK are good and cheap.
      • JimClark
        • 5913
        I on the otherhand had absolutely no problems with them on my 1/10th Hydro
        Billy Graham
        • bdp1174
          • 146
          I have them in a upgraded mystic a revolt and a motley crew.No issues so far.
          • homer49
            • 6
            Happy to report - changed all connectors from 4mm bullet to ec5's - used to heat up everything - wires - speed control - batteries - motor. Now, after changing, running larger prop (Prather 215) speed control & paralell wiring harness - almost no heat - Motor - gets warm but definately running cooler - warm to the touch only - batteries - get pretty warm but not unusually so - my guess is around 115, if that. Am running 2/5,000m paralell for 14.8v
