6s 5200 mah 45c-85c high discharge to much for 180 turnigy esc
  • topfli8979
    • Oct 2012
    • 6
    Hello,
    I am new to the fast electric boating world. Just picked a nice cat, turnigy 1600kv, turnigy 180 esc. Was wondering if running 2-3s 5200 45c-85c packs will fry my esc, it probably a stupid question. But I always ask first for advice.
    Thanks
  • Make-a-Wake
    FE Rules!
    • 6057
    The only variable that is in question is your motor size versus hull size. You batteries will never be too much for any ESC amperage-wise. Only drawing too many amps for the ESC will "fry" it. You could use 10,000 mah 90c's as an example, only a motor drawing more than 180a constant will blow it..............but you need to stay at 150 or less for safety room.
    • topfli8979
      • Oct 2012
      • 6
      is a 30 inch hull, not really sure what the motor draws amp wise.
      • jcald2000
        • 786
        Prop size determins amp draw.
        • KartRacer
          • Aug 2012
          • 363
          I am running seaking 180 w/ 2 5000 mah Dynogy 6s in parallel, Cnc 4514 prop. Pulling 132 max amps at 30,000 rpm. Still think hull is running a little wet, planning on moving batteries Back 1/2" for next run.
          KartRacer ~ Dennis B
          Delta Force Pirate 35'~Leopard 4092~1480Kv~Seaking 180~2X6S 65C 5000 Mha Dynogy Lipo,Parallel
