C rating
  • Paul21
    • 44
    C rating
    Question plan on running 12s in 67ich cat 5692 lepoard someone told me c rating doesnt mater on high voltage. I though c rating was for to handle the surge in amp draw even though high volts I.should still need high c rate right the.motors can.draw from 3000 to peak 5000 watts anyone know
    • 6057
    Why risk running low C rating anyways? Higher C rating batts are not that much more expensive, and sometimes are less expensive in the case of Turnigy/Flightmax lipos.
    • Paul21
      • 44
      True
      I agree but since I need minimum of 8 6s 5000 mah bats every little bit savings helps never used hk before worried about reliability havent found any us shop selling turnigy . Tks for input
      • Cooper
        • Jan 2011
        • 1168
        Email jan at kintec dot com ask about batts, he sells a lot but doesn't list much
          Your "someone" is a fool, don't listen to him. This is what can happen on a 10S setup with inadequate HK packs. In fact this is what happened.
          • Paul21
            • 44
            Tks for info on batts will email also I figure they put c rate for reason tgis third time get bad info local hoby shop what a shame u would think someone run bussness would know better wont take advice from local. I thought what he say wasnt right tks again
            • Paul21
              • 44
              Also I am one who has build thred hpr cto4 67 inch cat build been away for while health but rdy to finish all left is batts esc props all mouts instaled working on updating thread ps I tried kintec.com no go could u type site for batts again
              • MarkF
                dinogylipos.com
                • Mar 2008
                • 988
                Paul, I would like to recomend the Dinogy brand I sell. They are 65c rated and so far are some of the best batteries in testing that I've seen for myself and from my customers. There cheaper than TP and Hyperian but a little more than Hobbyking. I also give a 6 month warranty that I take care of. performancerclipos.com is my website but have a new one now called dinogylipos.com. I'm a little low on stock but have a big order comming in a week or so.
                Mark
