attatching cf lipo trays to df 29
  • driftah
    • 759
    so I grabbed a few carbon fiber lipo trays off ose and just wondered if there is a best way to attach them to my df29,I was thinking of scuffing the hull and the tab thingies and the tray in the glue spots and jb welding or epoxying them in.any suggestions guys...Im leaning towards the jb weld as a lotta guys including myself are using it for motor mounts etc.
  • Nosbig
    • 59
    I use epoxy for everything, I need to get a tube of JB weld and compare.
    Sand all contact surfaces well, wipe and dust off with a rag or paper towel, stick on with your favorite glue. You should be sanding for motor mounts as well.
    Bling rocket 32" T600 1400kv on 6S, Twin Lynx 3126 2200kv on 4S
    • Basstronics
      • 2384
      I used Epoxy on my Pursuit.
      One slow flip and it ripped it all apart.
      JB weld for sure.
      • Heaving Earth
        • 1929
        I used epoxy. Glued tabs onto plates, then drilled holes thru plate and tab, then used finishing resin and glued in place, dripping resin into holes. They've stayed on with 5s packs and 55 mph blow overs
