Battery Heat
  • OJ racer
    • Dec 2007
    • 170
    Battery Heat
    I'm having some difficulty with the heat of my batteries, wondering if you guys have some ideas. I run a DF22 with an x440, Feigao 540L 10-turn, and x-power 100a ESC. Even just one 7-cell nimh seems to get quite hot, so I was hoping maybe you had some ideas? I'm planning on running with 2 six cells in series, so I'd like to fix this. Any advice will be graetly appreciated, please and thank you!
  • jeffm912
    • Apr 2008
    • 153
    The heat is common on nickel batteries, the only way to stop it is to get rid of them and upgrade to lipos or prop down bringing your amp draw down. I know some even with the supervee and good 4200 cells, they still heated up. Also don't let the cells dump beyond 80% the last 20 always produces an immense amount of heat for the cell. Hope this helps.
    Jeff
    • OJ racer
      • Dec 2007
      • 170
      Thanks alot. I might have been draining them too much. That should help.
      • JimClark
        • 5902
        What batteries are they? Could also have to do with how they are built
        Billy Graham
        • OJ racer
          • Dec 2007
          • 170
          They are the 7-cell 4500s from OSE.
          • JimClark
            • 5902
            then they should be good I would look at prop size and also maybe friction in the drive train or the boat is just not running free enough
            Billy Graham
            • OJ racer
              • Dec 2007
              • 170
              What should I use to grease the motor bushings? Is it some special stuff? I have grimracer speedgrease but that's all.
              • JimClark
                • 5902
                I just use a light oil
                Billy Graham
                • OJ racer
                  • Dec 2007
                  • 170
                  Anybody know if trumpet valve oil would work? It's definitely a light oil.
                  • properchopper
                    rcgoatbuild@snotmail.com
                    • 6958
                    re :
                    When I was in High School marching band [ mid last century] we would carry a valve oil bottle filled with Scotch whiskey in our band uniforms. Not too good for the valves, but kept us warm in the end zone during the game
