spark
  • hydroman2112
    • 105
    spark
    is anything that be about elemenating spark when you plug up lipos to esc
  • oscarel
    • Dec 2009
    • 2135
    Search anti spark.
    Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
      • 7990
      Actually the spark is a good thing. It lets you know that the caps are good. The caps do wear out without warning. No spark means bad caps. Your choice, scared of a spark or the spark is your friend.
      • hydroman2112
        • 105
        ok i can live with spark
        • Rocstar
          Joel Mertz
          • 1509
          Also a spark eliminator will extend the life of the caps. So your call.....
          Sent from my DROIDX using Tapatalk 2
          • oscarel
            • Dec 2009
            • 2135
            Caps and connectors are cheap and easy to replace. ESC's easy, not so cheap. For higher voltage I'd say use them, Swordfish actually says to and supplies one with the 300 amp ESC.
            • Old Sloppy
              Harry from Atlanta
              • Jul 2007
              • 200
              Actually the spark is a good thing. the spark is your friend.
              Fluid is correct, heed his knowlege.
              Harry
              60" Expresscraft SuperCat
              (2) 2028 Castle motors 64.7 mph
              10s3p with x450/3 props
              15,000 mah 40c cells,
