What size & make bullet plugs are best.
  • martin
    • 2881
    As above i have Leopard 4092 - 1390kv & Gens Ace 3s 5000mah x 2 in series in a 41.5" Osprey v hull. What size bullet plugs would be best to keep restance down ie 6mm or 6.5mm or would 8mm be better or overkill. Also what make should i go for, i was going to use Castle as i had heard their very good plugs but have seen a few coments from those that have use then that they were loose when pluged in & it was only the tip of the fingers that were tight & you could wriggle the plug around. Are some of the various cheaper ones any good. Not looking to save money though as id rather only buy once & have good plugs. Thanks Martin.
    On a bigger hull motor I would be tempted to run 8mm.Fightercat has some sweet ones.On my1717 DF 35" I run 6.5's on my batteries(all my batteries are) into a parrallel plug and 8mm to ESC and Motor.Let me dig some pics up
    The first pic is of the parrallel connectors I made(I know they are backwards) and second is the various connectors with the large ones being FC,the middle Castle,and the single OSE.These are all 8mm.
