Dug a few old boats out of the closet today, most were 700 motor 12 cell nimh. After a few cycles the batts did not come back up, the cells have a tag 4200mah 1.299 volt @ 30 amp load. What would be a good replacement for these in lipo? Would like the same voltage or possibly better in the 30-40 amp draw range. Thanks
Replacing nimh with Lipo
I'm no pro, so someone might have to correct me, but by 12 cell I am assuming is 14.4 volts total?
If that is the case then a 4s lipo (14.8 volts) would work. If you got a 4000mah 20c it would be able to provide 80amps
Not sure if that is what you are looking for.The Speeders
*PB SW 26 BL *PB Formula FASTech
The Cruiser
*CBM Marlin Cruiser
The Pool Toys
*Proboat Mini-C (x2)
Battery discussion has a place. thread moved"A quick temper will make a fool of you soon enough."
