Battery vs. motor kv question.
  • Fastfish
    • Mar 2012
    • 34
    Hey guy's I'm sure this has been answered here before...please pass it on to me if so. Is the a formula out there that says what battery 2s, 4s etc. to different sized kv motors... I'm new to the battery world...I can tell you ever you need to know about nitro...
  • Bryan73
    • Mar 2012
    • 22
    Each cell ( 2s means 2 cells in series) on a lipo battery is 3.7 volts
    a 2s batery will be 7.4 volts and a 4s battery will be 14.8 volts
    from my understanding is you want to stay around 30,000 rpms with any given motor
    the KV number is sort of the formula
    a 2030 kv motor with a 4s battery will yield approximately 30,044 rpms
    2030 x 14.8 (4s battery)
    Basically .. the motor KV number times the volts of the batteries = motor RPMS
    I may be wrong though as I am new here also .. please anyone feel free to correct me if so
    • Chrisg81983
      • Jul 2011
      • 1585
      I like to try to stay around the 30,000 to 32,000 rpm range so you multiply kv of motor x battery voltage that will give you a general rpm range some like a little lower or higher rpm's but this usually works well for me
      • Fastfish
        • Mar 2012
        • 34
        Ok cool! So these guy's I've been watching on YouTube cranking speeds over 100 to 120 mph are turning some serious rpm's? WOW!
        • Fastfish
          • Mar 2012
          • 34
          what does the 20C or 30C etc. & 5000mAH stand for?
            • 6057
            The 47" mono in my signature is only turning 28,860 rpms at 10s nominal voltage of 37v................but it hits 70 mph cuz of the Big-A$$ prop!! Its not always rpms, but when you get into SAW racing they step it up a bit on the rpms.
            • Chrisg81983
              • Jul 2011
              • 1585
              Make a wake what seup ru running sounds nice
              • Fastfish
                • Mar 2012
                • 34
                I got it figured out...I did a online seach that explained everything...
                • searay skipper
                  • Apr 2012
                  • 69
                  care to share where you found the info please? also trying to get a better understanding of all this battery lingo here.
                  thanks.
                  • Geeves
                    • 69
                    thanks.
                    • searay skipper
                      • Apr 2012
                      • 69
                      great thanks.
                      • Diesel6401
                        Memento Vivere
                        • 4391
                        Download the chart on the first page and first post: http://forums.offshoreelectrics.com/...ad.php?t=23729
                        Sent from my T-Mobile G2 using Tapatalk 2
                        - Diesel's Youtube
                        - Diesel's Fleet
                        • searay skipper
                          • Apr 2012
                          • 69
                          got it....thanks.
