You think my Lipo "fix" is OK?
  • Make-a-Wake
    FE Rules!
    • 6057
    Ran my 39" 6s2p mono yesterday and it seemed slow, then the LVC cut in.............didnt seem right so i brought it in. Checked all the batts with my lead tester and one batt measure 8.1v...........unplugged and brought it home. Cut it open and one of the solders had 'seperated'...............here's my fix, I'm thinking it should work.....................input?
  • keithbradley
    • 3671
    Is there a trace below it? I've done that before and it worked ok until it had a decent load on it then it opened in the same spot. I ended up putting a jumper wire from one point to the other along with the solder and it worked.
    Either way it's a lipo that's probably on it's way out. You do run the risk of the solder melting onto one of the other cell connections and causing a short if it happens again, which could lead to fire. It might be worth it to retire that lipo or use it in vehicles where the aftermath of a fire isn't as bad.
    www.keithbradleyboats.com
    • Make-a-Wake
      FE Rules!
      • 6057
      There is no trace below it..........i had a bit of trouble bridging it with the solder but finally got it there..............i was thinking a piece of wire too. The Lipo has never really been stressed being only run in 2p since new. Its solid and "square".....................hmmm.
      • Make-a-Wake
        FE Rules!
        • 6057
        Well, some blue tape and she's almost new again Saved myself about 40 bucks!
        • Make-a-Wake
          FE Rules!
          • 6057
          Well the lipo just passed the test of 4 minutes of WOT.............guess im good to go
          • Drax21
            • Jul 2011
            • 1077
            Looks like a good fix to me. Hope it holds up for you
