5s lipos
  • karlhh
    • 104
    5s lipos
    I have two protec 5600mah 2s 65c lipo im looking to run a 5s set up im in need for two 3s lipos with 5600 mah and 65c anybody know of such? what else can i do to have two sets without buying four more batteries?
  • steveo
    • 1595
    if you cant find any you may have to sell then buy new it sucks i know, what are you putting this in maybe there are more options for you, where in florida are you?
    • karlhh
      • 104
      Im on the west cost of florida in bradenton just south of tampa. its going in miss geico proboat i put in a seaking 180 and trying different props. stock motor.
      • tim v
        brushless everything.....
        • 166
        instead of new batts have you tried propping up ?
        :canada
        • Chilli
          • 3204
          Be carefull using batteries from different manufacturers at the same time. The numbers on the packs may be the same but there is a good chance they are different on the inside. That could mean trouble.
          Mike Chirillo
          www.capitolrcmodelboats.com
          • karlhh
            • 104
            Im going to try m445 prop what should i watch for heat on the batteries and motor?
            • tim v
              • 166
              motor esc batts connections... take it for a quick blast then check it...
              :canada
              • karlhh
                • 104
                what temps are to high?
                • Boaterguy
                  • 1779
                  if you don't have a thermometer, do the "5 seconnd" (i usually use indefinitely) test.
                  if you do not feel comfortable holding on to the motor/ esc or batts for a significant quantity of time, they are too hot.
                  if you have a way to test the exact temps let us know and we can tell you.
                  • karlhh
                    • 104
                    Yes I have a thermal gun that uses laser.
                    • Boaterguy
                      • 1779
                      everything should stay under 120-140F, if something is higher, you need to prop down or change something.
