lipo question...
  • Rob DeAngelis
    • 296
    lipo question...
    hey guys im an ex nitro freak and am now getting into the brushless scene... I purchased an aquacraft ul-1 and am currently running the stock 60 amp esc and the stock 2030 kv motor. Im using grim racer speed packs 4200 mah 30c 2s packs... is this a good choice or should I go bigger? if so can my stock set up handle it??? Also im using an onyx 235 charger from duratrax... Is there a way to charge 2 packs at the same time??? thanks...
    Lakeside entertainer
    • 6057
    Those packs are fine for your setup, going bigger wont hurt anything, adds a bit more weight which is not always a bad thing, but gives longer runtime. I'll suggest two of these for a bit more punch and more runtime........CRAZY cheap!!
    http://www.hobbyking.com/hobbyking/s...arehouse_.html
    Your onyx can charge two 2s packs in series
    • Rob DeAngelis
      • 296
      cool, thanks man... I will look into it as well as the gr 5000mah...
      • stadiumyamaha
        • 1371
        2 5000mah will fit fine and give you more run time. I also will run one single 4s Pack at time nut I have a bunch of 4s packs from other boats. Also look at the sky and gens lipos from hobbypartz. I've had great luck with both.
        • sailr
          • Nov 2007
          • 7128
          There are some new batteries just coming out. They have impressive specs and are attractively priced. They are shipped in the U.S. from a U.S. warehouse. I will be trying some soon.
          There is an active forum on RC groups about the batteries. http://www.rcgroups.com/forums/showt...8#post19880728
          Personally, I would recommend these over the Hobbyking or Hobbypartz packs.
          Mini Cat Racing USA
          www.minicatracingusa.com
            • 6057
            Good prices on those..................40c 5000's for 29 bucks, let us know how they work out.
