any one make a connector that will go from two 2s packs to a 4s pack connector
  • sigelitest
    • Jul 2011
    • 329
    i am looking for a Y connector for the feedback connectors on the bat packs
    I like to use 2s packs for my boats and series them to 4s or 6s. I am looking for an adaptor for my charger for the feed back connector.
  • LarrysDrifter
    Big Booty Daddy
    • 3278
    Whats a feedback connector?
      • 4297
      What charger are you using and lipos ?
      You need a balance board like one of this,http://helidirect.com/bantam-charger...1_525_1034.hdx
      • Chilli
        • 3067
        Are you looking for a balance tap adapter to charge two 2s packs in series as a single 4s pack?
        Mike Chirillo
        www.capitolrcmodelboats.com
        • sigelitest
          • Jul 2011
          • 329
          Yep that is what i want. I didn't know what it was called
          • sigelitest
            • Jul 2011
            • 329
            I have a board now that must be setup for Parallel. it had 3 2s taps in a row but it would arc if i tried to plug both in.
              • 4297
              When you tried to plug in the balance plugs, Were the main wires plugged in first ?
              • sigelitest
                • Jul 2011
                • 329
                Nope this is a pic of the board
                  • 4297
                  You should plug in your red + wire and black - wire first than your balance plugs or they will arc.
                  • Chilli
                    • 3067
                    Make sure the board you purchased is correct for your packs. There are a half dozen types of balance taps and some are wired differently.
                    I had to make my own harness for my Hyperion packs.
                    If the board doesnt work out for you, there is plenty of info on the net on how to make your own series adapters. Be carefull!!
                    Mike Chirillo
