Any one try these batteries?
  • RandyatBBY
    • 3943
    Randy
    BBY Racing
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    DSC02846.JPGRand,
    I picked up some of these 2S 40C packs. Good punch so far. I've looked over the one you pictured for a spec battery & might give it a try based on the price & local shipping.
    • Diesel6401
      Memento Vivere
      • 4391
      Gens Ace ROCK!!!!!! I love them! My Data logging shows they provide better performance then Turnigy packs! Less voltage drop underload and increased performance!
      - Diesel's Youtube
      - Diesel's Fleet
      • RandyatBBY
        • 3943
        I was wondering if the amp rating could be trusted? I know you never try to pull max., but with two of these packs in paralleled could I feel safe to pull 175 to 200 amps?
        I almost always buy Pollyquest 25C packs and can use them for two to three years with no problems.
        Randy
        BBY Racing
        • RandyatBBY
          • 3943
          No answers, 73 views, Can any one help?
          I hate to invest to see if the cells are what they call them. but no info I had to try, I am running out of time. I just bought these to test and see of they are correctly rated. I will be pulling 175 to 210amps constant. with 2S2P
          http://www.hobbyking.com/hobbyking/s...dProduct=17264
          Randy
          BBY Racing
          • RandyatBBY
            • 3943
            What type of amps did you pull constantly. Same question for you Tony? thanks in advance for your help, I am trying to be prepared for the WW.
            Randy
            BBY Racing
            • Diesel6401
              Memento Vivere
              • 4391
              I don't think you will have any problems with a them at all. Run a 2p setup and your golden. I personally like the gens ace packs better then the turnigy packs. Here's a thread about these batteries http://forums.offshoreelectrics.com/...attery-Testing. I wouldn't hesitate running them.
              - Diesel's Youtube
              - Diesel's Fleet
              • RandyatBBY
                • 3943
                Thank you for the link. It will help me understand I have some reading to do tonight!
                Randy
                BBY Racing
                • properchopper
                  • 7708
                  Randy,
                  I've only used the Gen Ace 40C 2S 5000's in series in my SAW spec boat - the UL-1 motor with Brian's prop was probably pulling in the vicinity of around 80-100 amps in the short runs. Nothing ever got hot, batteries had good punch and got better after 5+ runs. I like them.
                  • Drax21
                    • Jul 2011
                    • 1077
                    In all the recent tests. Gens Ace packs have come out on top even beating Thunder Power in some areas.
                    • stadiumyamaha
                      • 1371
                      I run those same packs 4s2p in a 32 mono w cc1515 2200kv. Although I don't data log I can tell you running low to mid 50s mph on a m545 my set up is never hot. Motor in the 80s esc in the 90s and cells in the 120° range.
                      I'm also getting the same performance from the sky lipos as well.
                      not racing so don't have enough cycles to know about longevity.
                      • sailr
                        • 7128
                        There are some new batteries just coming out. They have impressive specs and are attractively priced. They are shipped in the U.S. from a U.S. warehouse. I will be trying some soon.
                        There is an active forum on RC groups about the batteries. http://www.rcgroups.com/forums/showt...8#post19880728
                        Mini Cat Racing USA
                        www.minicatracingusa.com
                        • RandyatBBY
                          • 3943
                          I need to break in the Turnegy and then test on my hot setups. Then if the 2S2P go OK I will look at the 4S2P for other setups. I still have to keep in mind that I gang the packs together to make 10S2P for some of my boats.
                          Randy
                          BBY Racing
                          • properchopper
                            • 7708
                            Randy, FWIW I just got back from the lake where I ran my SAW Drifter with two 2S 40C 5000mah GenAce paks I bought used right here. They were superb !!
                            One thing to watch out for : some of the sku's have 4 mm wire plug-ins; others labeled "Direct" have thicker wires soldered intetrnally. Just so you know.
                            • Drax21
                              • Jul 2011
                              • 1077
                              Yes the plug-ins are a big NO NO
