B- grade lipos?
  • Boaterguy
    • 1760
    B- grade lipos?
    has anyone ever tried them? they look really cheap and I don't know if they are worth it, i'd be getting the 5000 45C's.
    I don't understand, when they say they are lower quality, does that mean they aren't up to the 5000mah 45C task? (200 amps or so)
  • norbique
    • 356
    They say these packs have cells with higher internal resistance. This is not something you want in a high amp setup. If you over current these packs they will probably baloon up/loose their capacity etc. For lower current applications it should be ok. For a slow retreival boat for example.
    Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.
    - Mark Twain
    • Boaterguy
      • 1760
      that's what I don't understand, the IR IS the "c" rating, so if it's a 45C battery, how does it have higher IR than any other 45C battery?
      I guess numbers are just pulled out of the air.
      • norbique
        • 356
        I think they are from the same batch as the good 45C ones, but due to their higher IR they were labeled B grade. The 45C label remained however.
        - Mark Twain
        • Alfa Spirit
          • 2131
          What is a B- grade LiPo? Cheap batteries like on ebay?
          • norbique
            • 356
            no, the B-grade are sold on HK website.
            - Mark Twain
            • AlanN
              • Mar 2008
              • 334
              No, IR is not the C rating. IR is the internal resistance. C is the amp rating of the cells.
              • Drax21
                • Jul 2011
                • 1021
                I had 3s B-Grade batteries 5000mah 40-50c. Good power on them, were still good after 10 runs. Then I sold them as I no longer needed them. They always balanced well sometimes only being 0.01 out. B grade batteries they say only only last 60 cycles. 60 Cycles is loads enough for me. The normal Turnigy Lipos are meant to last over 100 cycles but I wouldn't count on that.
                • Boaterguy
                  • 1760
                  well the internal resistance of the cells would determine how many amps can pass through the cell, at least that's how i thought it was.
                  • Rok Krawl
                    • Oct 2011
                    • 32
                    Well the b- grade batts are much cheaper for a reason. You may get lots of runs out of them or they could puff up and go out on you after a few runs. Work well for a crawler truck. But if it were me and my boat, id spend the extra few bucks for good packs. I run a buddies turnigy packs in boat. Work great. The other non b-grade packs they sell are not much more money compared to dynamite, traxxas , etc...
                    • AlanN
                      • Mar 2008
                      • 334
                      The IR is a real number that you can obtain from a decent charger like a Hyperion. That tells you more of how the cells will perform than the C rating.
                      • norbique
                        • 356
                        Very true!
                        The iChargers also can tell you the IR of the battery pack connected.
                        - Mark Twain
