Im looking for a charger that will balance charge 4 2s lipos all at once at 5amps each anyone got any decent ideas,unsure about the hitec or hobbyking ones chime in please?
need advice on charger
One of my buddies just bought one of the dual-output 400W chargers from HobbyKing (Mega 200Wx2, $96). This one will do the job easily with a parallel charge board or home-made adapter. I'm really impressed with the thing so far and will be picking one up myself.
Take it easy,
desmobob
You set up to parallel charge all at once, right? Prob with the Quad output ones is they are all 50 watt max per output, if that matters.... I recently bought me a 0720i so I should not have to worry about a charger for a few decades... I have 2 parallel boards in the event I am charging 3S and 2S at the same time (two output ports), I can charge a doz. batts as long a power supply can handle it. Seems like you are lookng for something more specific though..... No?
But yes,
200W should be enough on a 4 batt, 2S-each @ 5 amps-each setup. (170 watts)
Thanks Diegoboy. (I think)Originally posted by Diegoboy View PostThread moved
Anywho, Driftah. i can here you thinking..... I was playing with same ideas in the spring. And decided that if i added up just the last 3 chargers I have owned, I would have saved up more than enough to get a great charger. So I finally bought a great charger. To be honest, the Hyperions are very nice. I like it much better than the Imax series among others. My vote is for the Hyperion.....
