No spark resistor
  • Boaterguy
    • 1760
    No spark resistor
    so today I canged out my 119 ohm resistor (4 sec charge time) for a smaller one, because it was heating up during charging. I went to the no spark calculator, and with 3350uF on 5S it told me to use 15 ohms.
    I soldered up a 15 ohm resistor (brown, green, black, gold) and plugged it in. the resistor puffed up in smoke and I disconnected everything as quick as possible.
    what happened? did I do something wrong? the resistor is pretty old (from my 50 yr old uncles university days) but doesn't look or work any different than a modern resistor, the previous one was just as old and worked fine.
  • m4a1usr
    Fast Electric Addict
    • 2032
    Do you know what wattage the 15 ohm was? You should probably using at least a 2 watt. As resistance values go down, surge current will increase.
    John
    Change is the one Constant
    • Boaterguy
      • 1760
      How do I figure out the wattage of a resistor?
      • m4a1usr
        • 2032
        Resistors come in different wattage values( 1/8w, 1/4w, 1/2w, 1w etc) usually printed on them.
        Read more: http://www.bcae1.com/resistrs.htm
        John
        • Boaterguy
          • 1760
          Thank you, I'll just go buy one instead of going through old ones.
          • kookie_guy
            • 897
            The wattage was way too low. If it looked like your average size resistor, then it was probably 1/4 or 1/2 watt. 2 watt is the minimum you should be using.
            • m4a1usr
              • 2032
              Always remember to disconnect the anti spark circuit once the main battery/esc bullet has been connected. Leaving the anti spark resistor connected will only generate waste heat. Its not supposed to remain connected once the main bullets are attached.
              John
              • Flying Scotsman
                Fast Electric Adict!
                • 5190
                Thank you John for all your expert knowledge.....do you still have a torpedo kicking around in the basement?
                Douggie
                • Jacked1
                  • Jun 2010
                  • 772
                  You will want a resistor that it's wattage is more than (V^2)/R. Power=(V^2)/R
                  V is your battery voltage and R is the resistance. :)
                  This will guarantee that you have no more resistor fires.
                  • Boaterguy
                    • 1760
                    okay, R at 15, voltage at 18.5. I get 22.5 watts, I don't know if I can find a 23 watt resistor anywhere.
                    • Jacked1
                      • Jun 2010
                      • 772
                      A 10 Ohm 2watt will do for this. (That is what i have) I was thinking RMS on my other post , that would work for any application you would need a resistor for.
                      • Boaterguy
                        • 1760
                        will have to survive without one for tomorrow but when I get back I'll get around to getting one.
                        • m4a1usr
                          • 2032
                          Douggie
                          Ha, ha. You ole' dog Douggie. Nah. While I tried to edge on the side of the markets and inflation, possesion of government hardware only garantees a lifetime membership in to a change in lifestyle choices. I prefer as an alternative to pick up cans along the road side as my retirement plan. Whats the worst that can happen? I become a Democrat and glue myazz to the "system"?
                          John
                          • norbique
                            • 356
                            I use 18 ohm 2w resistors on my 6s setups. Work well. Resistors become slightly warm but nothing serious. I'm charging 5000uF total cap.
                            Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.
                            - Mark Twain
                            • drwayne
                              • 2977
                              I use 10ohm5W ceramic block ----[10R 5W ]----
                              on 6S for 8800uf
                              25cents
                              2second charge time.
                              cool as a cucumber ...
                              some think batts are not connected because click, click, click, no zap !
                              W
