"Deep Cycle" or "Starting" battery for lakeside charging; which is better ?
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    My 3 yr old deep cycle battery is history; need to buy another battery - wondering which is better. Need to hold voltage up the highest; my Hyperion chargers kick out a "low input voltage" error message when the voltage of the storage battery drops some. I seem to remember that there's a way to set the LV threshold on the Hyperions but can't find the info. Anyone ?
  • dana
    • Mar 2010
    • 3660
    Why not get a jump pack? Or maybe try a drycell. Holds more charge than the wet cell
    • JimClark
      • 5913
      I think a deep cycle
      Billy Graham
      • Basstronics
        • 2384
        What about a gel cell like an Optima? Its a pricey buy...
        The yellow tops would work also.
        You might be able to pick one up on craigs list local. Also many of the car audio batteries would work- sealed gel cell types.
        • Stinger9D9
          • Jun 2007
          • 378
          You could run the chargers on 2 deep cycle batteries in series (24 volts). It'll lower your amp draw and might help your Hyperions run cooler by not having to step up the voltage as much.
          Twice as much weight to lug around though...
          • properchopper
            • 7708
            Thanks for the suggestions, But... Optimas are out of my price range .... two deep cycle batteries too, plus I have to carry my battery up a flight of stairs to recharge it so two batteries would be tough. A jump pack has a small overall capacity....not sure what a dry cell is. I'm still looking to find out the difference between a Deep Cycle and Starting battery - I can get either for less than $ 100 - just would like to know what the difference is between them & which would make a better Lakeside battery.
            Thoughts ? John ??
            • JimClark
              • 5913
              Deep cycle handles deep discharge much better than a starting battery
              Billy Graham
              • marko500
                • 862
                A deep-cycle lead-acid battery is designed to be regularly deeply discharged using most of its capacity. In contrast, starter batteries (e.g. most automotive batteries) are designed to deliver short, high current burst for cranking the engine, and to be frequently discharged of only a very small part of their capacity.
                Found this online, hope it helps.
                In my full size boat I have a battery that's a combination heavy duty marine starting/deep cycle battery.
                Mark
                Mark
                • TheShaughnessy
                  • 1461
                  Tony,
                  These go on sale even lower sometimes, I've seen them and 98.99 before. 800 watts should be more then enough power and I doubt it"ll consume much gas.
                  http://www.harborfreight.com/engines...tor-66619.html.
                  If you left it on all day you could expect about 5 hours for a gallon of gas a 3.60-3.99 a gallon plus oil. I'm not sure if charging a battery is costing as much or not.
                  here are the specs
                  Name 800 Rated Watts/900 Max Watts Portable Generator
                  SKU 66619
                  Brand Chicago Electric Generators
                  Run Time 5 hrs at 50% load
                  Fuel Shut Off Fuel Shut Off
                  Mounting Type Horizontal
                  Output Watts 800
                  Output Voltage 120
                  Output Amps 20
                  Decibel Level 91
                  Outlet Receptacles 1
                  Shipping Volume 1.867
                  Certifications/Approvals EPA and CARB
                  RPM Rated 3600
                  Fuel Tank Capacity 1.1 gal
                  Start Type Recoil
                  Max Output Watts 900
                  Horsepower 2
                  Manufacturer Warranty Detail
                  • sundog
                    Platinum Card Member
                    • Feb 2009
                    • 940
                    Stinger9D9 and Jim Clark both have valid arguments. A deep cycle battery will allow deeper discharges without damage. That's why they are used in solar power applications as well as golf carts and trolling motor use. And two of them (24v) will be easier on the charger (but more weight to tote). So the best solution might be two small deep cycle batteries. BTW, that deep cycle battery should have given you another couple years of service IMO, - were you charging it back fully at the end of every session and checking the water levels?
                    • properchopper
                      • 7708
                      My living arrangement ( I live in an upstairs apartment) makes it necessary to tote the battery upstairs to my apt. to charge it; there's nowhere to plug in a charger downstairs. These batteries are Heavy ! Consequently I've been lax, as you pointed out both in re-charging and checling water levels - my bad. Also, the apt. rules exclude storing gas-powered devices in the parking areas, and keeping a generator in my apt. or car could be smelly and dangerous. Looks like I'll spring for a new deep cycle battery and be more observant of maintenence including installing a led voltage monitor (Radio Shack has a nice, small goodie just for these applications-I have one on my motorcycle). Live & Learn !
                      • 7500RPM
                        • 110
                        Go and buy an Inverter Drive Generator, lots of companys make them now and the prices are well under $1000.00 I am seriously looking into buying one now. Costco canada has a 2000 watt inverter gen for $500.00 and I just heard it run WITH a load on it, Very Quiet !
                        There is no replacement for displacement, I guess I just have to Buzz it higher!
                        • sundog
                          • Feb 2009
                          • 940
                          I've prematurely ruined a deep cycle battery or two in the past. Isn't that how you learn?! Costly education. Another solution might be to get a solar panel and let it charge the battery. A single panel charger won't overcharge a deep cycle - you can leave it hooked up until you need it. Of course you'd need a secure storage location. Times being what they are, it might grow legs and walk away.
                          • jeepme
                            • 59
                            I am going to try the solor panel thing next week. I am going to be on a houseboat for a week so I got a 45watt 2.55 amp solor panel and controller to hook up to my optima yellow top. I will let ya know how it works.
                            • properchopper
                              • 7708
                              Hey Sundog, Don't take this the wrong way , but I feel a little better knowing that I'm not the only one to mishandle a deep cycle battery. Looks like I'll cough up for a nice new battery & keep up the maintenence. I do like the solar panel idea, but security is an issue as you pointed out.
