MY Connection keep melting (ec5 and 6mm CC bullets) HELP!!!!!
  • Frazzo420
    • Jun 2011
    • 48
    I have a pursuit with leopard 2000kv 4074 and a seaking 180a esc. I use 2p4s 5000mah batts in "parallel". obviously........ if i run it at wot for about 1.5-2 min it dies. the batteries and esc use ec5 conns and my motor uses CC6.5mm bullets.
    The proplem is the battery ec5 plastic is melting and the motor terminals are de soldering..... i think the motor connectors issue is mabe *!***!***!***!**ty solder i am using 60/40 BernzOmatic silver bearing lead free solder... is this good enough????
  • Frazzo420
    • Jun 2011
    • 48
    oh and a x442 prop and one piece shaft
    • domwilson
      • 4411
      Do you have any pics of the inside? How long are your battery wires? Have you tried 6mm connectors on the batteries?
      Government Moto:
        • 7512
        60/40 is pretty much the norm for solder...don't take this personally, but how are your soldering skills?
        • Frazzo420
          • Jun 2011
          • 48
          I went to school to be a electronics technician.......so there as good as they could be
          i did order alot of 6mm bullets the other day so ill guess ill have to wait and see...
          also i do have the video of the boat from in the water to desolderation 1m32sec.... if you want to see how it performed
          • Frazzo420
            • Jun 2011
            • 48
            video now up
