Need help on 12s setup
  • Mel279
    • Dec 2008
    • 873
    hi guys
    I need you guys advise on my 12s setup twin cat 135(54")
    Motor: 2 x Leopard 5692 / 730kv
    Esc: 2 x SF HV 240A
    Prop: CR 447's ...thats the only one I have.
    I was thinking of getting some Gens ace 6s 25c 5500mah and will be set in series for 12s. I would like to know is the c rating enough for that setup without the lipo getting hot and puff.
  • Fast Guy
    • 135
    Keep in mind that the 25c rating is very conservitive on the Gens Ace and in tests I have seen they should be rated at 40c. Get yourself a data loger like a Eagletree and do short runs till you get it sorted out.
    • jcald2000
      • 786
      NO!!, 45C min.
      • Mel279
        • Dec 2008
        • 873
        Originally posted by jcald2000 View Post
        NO!!, 45C min.
        ok thanks, but do you ever run a big twin cat with 12s before?
        • Fast Guy
          • 135
          I don't know how much HP you need to get that big cat going but your 25c 5500ma batteries are going st give you 137.5a and at 44.4v thats going to make 8HP. Your batteries fully charged are going to be 50v and that makes over 9HP. A full sized man in a 12ft boat with a 8HP outboard will get up on plane so I think your cat should too. Not sure where the need for 45c is comming from.
          • Mel279
            • Dec 2008
            • 873
            From what I know, high voltage require less amp draw, the higher the voltage, the lower the amp, Im not sure about that. But anyway, thanks for your advise.
            • U1Racing
              • 62
              remember what they say about electricity: it's not the voltage that will kill you, but the amperage will. trust them when they say 40c at an absolute min!! the fact that high voltage has less amp draw still doesn't prevent you from having a 5-second current spike!!
              too much power not in the FE racing dictionary
              • Fast Guy
                • 135
                You are correct in your thinking. Thats why you see hi voltage in high output systems. What you need to be concerned with in electric power systems is the watts (volts x amps) which = HP (746 watts = 1HP). If you do a search you should be able to find out how many HP you need for your boat. From there you can multiply the number of HP by 746 watts to get the power system you are going to need.
                For example if you need 5HP
                5HP x 746w = 3730w
                3730 divided by 44.4v = 84a on 12s
                3730 divided by 22.2v = 168a on 6s
                You also need to to try to get your max prop RPM between 25000 and 35000.
                Your 730kv motor on 12s is going to be a very hot setup at 32412 RPM. High RPM means smaller props and touchier setup. The amperage your motors can handle also comes into play. Too much and they will overheat. If it works out for you you are going to have one fast cat.
                • drwayne
                  • 3012
                  Gens Ace also produce a 40C5000 cell.
                  • Mel279
                    • Dec 2008
                    • 873
                    thanks, I don't see that coming
                    • Fast Guy
                      • 135
                      In tests the 25c Gens Ace performed better than a lot of 40c batteries including some big name brands. Makes you wonder if their 40c cells are going to be 80c.
                      • Mel279
                        • Dec 2008
                        • 873
                        Thinking of getting them instead, let see how it goes
                        • drwayne
                          • 3012
                          and 45/90 and 55/110...
                          55/100 at a max of 3300mAh
                          45/90 max 6400mAh ... thats 288A cont ....
                          They had lots on show at the Beijing Hobby Expo .....
                          :dreamysmile:
                          • Mel279
                            • Dec 2008
                            • 873
                            :dreamysmile:
                            drwayne
                            are those 6s lipo c rating?
                            • drwayne
                              • 3012
                              separate cells .. combine into packs yourself.
                              They offered assembly, but their QC was average for small qty sub 50packs.
                              Yes, I have trialed them. Work a treat.
