Charge/discharge NiMh
  • racer66
    • 68
    Ok, I have a 5100mah 7.2v NiMh battery and a Accucell 6charger. To charge the battery I am going to set it at 5.1 amps.
    Now to discharge it, what are amps and volts?
  • racer66
    • 68
    no one
    • SweetZ28
      • 1535
      NIMH don't need discharging they have no memory like the older Nicad battery packs do.
      Also make sure you set your MV sensitivity to 3 to 5 MV because i am pretty sure the auto mode it's 7mv and your battery will over heat if your charger is the same as most of the china chargers.
      WWW.PPRSLOTS.COM
      • 785boats
        Wet Track Racing
        • 3423
        NiMh can be charged up from any state of discharge.
        But they should be stored fully charged.
        Every now & then (say every 5 runs or so) it is a good idea to fully discharged down to 0.9V per cell. For a 6 cell pack that's 5.4V.
        It's best done after a run in the boat, when the batteries are nearly drained, & at a 1 Amp discharge rate.
        Then charge up at 1/2C (2.5A).
        This procedure allows the cells to balance.
        At least that's the way we used to do it.
        Cheers.
        Paul.
