Whats the max race cell count on a feigao 6XL?
  • TotalPackage
    • 622
    I have this motor in my 12th scale U-25 pay n pak on 3s and a x642 whats the max cell count I can run safely? This thing wants to take off is running flat it's just light as heck. What do i need to do?
  • 6sHyper
    <<<Surfs up!
    • 640
    380xl or 540xl?? 3s on 380xl max 4s on 540xl max, and thats probably too much prop i bet it will stick to the water better on something smaller
    • TotalPackage
      • 622
      540 6xl on 3slipo
      • 6sHyper
        <<<Surfs up!
        • 640
        kind of a crappy choice in kv, 3s is max i would run on that, she will roast on 4s. lol 41k on a Feigao, not gonna last more than a few runs i bet.
        • TotalPackage
          • 622
          Why is it crappy? It runs good on 3 s im only wondering about more cells to hold the nose down. I think the 6 xl runs good @ 3slipo
          • domwilson
            • 4411
            Maybe 3S2P?
            Government Moto:
            • TotalPackage
              • 622
              HMM good thought dont know if I can get it in the nose. I wish I would have planned for battery compartments in the sponsons.
              • 785boats
                Wet Track Racing
                • 3423
                You could lower the strut a bit to help keep the nose down. Unless it's true scale & has a straight shaft, that is.
                If you can't fit 2 x 3s packs in there, don't be afraid to add a bit of lead ballast up the front. Just make sure it's attached well. You don't it coming loose in a high speed tumble.
                Just a couple of thoughts that can work.
                Paul.
                • Simon.O.
                  • 1611
                  Maybe apples and onions but I run a 540-6XL in a rigger that is good for 4-6 passes and that is on 4 cells to a 640, or 642
                  I assume you are after a race setup which is something I know very little about so I'll leave that to seasoned racers.
                  On 3S the 6xl is not a real stunner for me in a rigger but it works for you so far, so stay with it.
                  If you like the 3S then start with some ballast, I have had one hydro and that needed ballast to tame it down.
                  Once you establish your needed weight and location you may be able to go with bigger mAh packs and remove lead.
                  Over to you.
                  • BILL OXIDEAN
                    • Sep 2008
                    • 1561
                    Higher cell count will raise the nose even more. 2p MIGHT work, but I'd play with the strut and weight placement. I'm the master of manipulating feather light boats.
                    • TotalPackage
                      • 622
                      Holding world titles you can be all the master you want My friend. I guess Ill lower the strut more.
                      "I assume you are after a race setup which is something I know very little about so I'll leave that to seasoned racers.
                      On 3S the 6xl is not a real stunner for me in a rigger but it works for you so far, so stay with it."
                      Seriously Simon If I could get this nose to lay flat on the water this boat would move. Its real quick at 1/4 to half throttle but if I open it up it really airs out. It turns Good i just need to make it run a little wetter.
                      just a note for the balsa models. Close off your turbine exhaust and the air ducts with expandable foam or somme thing coz if it flips and water catches in theses areas it will rip the hatch apart.
                      Oh Bill I really wish I could try a sensored novak setup in this puppy. Do the make a sensored model that would be close to this 6xl? When you get some new stuff I want dibs on a sensored setup you have.
                      Ill get some video on it this weekend so you can see its attitude and help me make some adjustments.
                      Anyone that thinks these scratch built Finlay models wont move out check this :http://www.youtube.com/watch?v=
                      Lastly building from scratch is so gratyfying.
                      • BILL OXIDEAN
                        • Sep 2008
                        • 1561
                        Anyone who thinks a 1/12th scale hydro wont move is a nincompoop PERIOD. I had to compete against one a few years back at the SAWS in GA it was one of the toughest battles i ever fought. Almost went home empty handed, my micro hydro Vs a 12th scale pay n pak
                        We were running 19turn brushed motors on 8-cells nimh he took my record with his 48mph run, but after he packed up, I stayed and blasted through at 52..
                        Neat little boats, dosen't take much power to get em on flight. they were designed in the early to mid nineties when power was lacking. Lifty little sonofaguns..
                          • 9481
                          I ran a 6XL on 4s once in my Mean Machine and it was nuts!
                          I only got about 1min because it snapped the shaft
                          • Simon.O.
                            • 1611
                            Motor shaft or drive shaft (wire or flex) Just curious as I love my 6XL on 4S
                              • 9481
                              it was a flex shaft, it snapped like a noddle!
                              what rigger are you running a 6XL in?
