I found an amp watt meter and want to know if this will be ok?
whats a good amp meter and will this work?
I have that one it works ok I guess ...Just make sure you give it a fine coat of corrosion X .... mine got wet and stopped working so i coated it with corrosion x lightly and now it works ... and now should be protected from further water contact.
i'm in the same boat as you, i had the turnigy watts meter but it blew cause it was only rated 130a, i started a topic and seems the eagletree 150amp is the way to go, and guys are using the donut add on to read up to 300 amps, at least i think thats what there doing.
do ou have a link? and whats the donut add on?Originally posted by 6sHyper View Posti'm in the same boat as you, i had the turnigy watts meter but it blew cause it was only rated 130a, i started a topic and seems the eagletree 150amp is the way to go, and guys are using the donut add on to read up to 300 amps, at least i think thats what there doing.miss gieco cc 1518 62.1mph [/COLOR][/B] Delta Force 33" cc 1717
There are 2 ways to measure amps. 1. direct series connection, and 2. inductive pickup. The two are separate as far as eagle tree goes. They are different systems unless you pay some major bucks for DMM that can do both.Originally posted by bbosncali View Postdo ou have a link? and whats the donut add on?IMPBA 20481S D-12
