Balance Y adapters
  • Flyguy55
    • 218
    Balance Y adapters
    Does anyone make lipo Y balancing adapters ? Need to adapt 2 - 3S JST plugs into 1- 6S Hyperion plug .
    I want to be able to charge 2 packs as 6S1P . I need 2 adapter cords .
    Thanks , Dick
  • Chilli
    • 3204
    I think this is what you need. Hyperion makes a two 3S to 6S Y adapter for both XH and XP battery taps.
    Mike Chirillo
    www.capitolrcmodelboats.com
    • Flyguy55
      • 218
      Thanks , close , but I don't think either of those listed will work. Both 3S plugs are HP . I need 3S JST plugs.
      Dick
      • Chilli
        • 3204
        Been there!! I had to make my own to charge two 2S packs as a 4s.
        What brand packs and charger are you using???
        Mike Chirillo
        • egneg
          • 4759
          That will work with converters from RC Lipos.
          http://www.rclipos.com/Accessories.htm#PQALAdapters
          IMPBA 20481S D-12
          • Flyguy55
            • 218
            Hyperion Duo Charger . The T NanoTec 3S lipos came with JST plugs . My 4S T NanoTec 's all came with Hyperion plugs . Its what I expected this time.
            I emailed RC Lipos , He suggested Mike at Cheap Battery Packs . I'm waiting for a response from Mike
            Yes , I can make my own, I made some for charging 2 - 4S packs as 8S. Then I had lots of left over connectors. If I have to order connectors anyway I'll try to get the Ys already made up.
            I'm setting up an AC Pro Sp 40 hull I never got around to building when I raced Nitro many yrs ago . NEU 1527 1Y , 180 HV ESC . 6S 2P 4000 T NanoTec Lipos .
              try for plugs http://www.helidirect.com/index.php
              • Flyguy55
                • 218
                Cheap battery packs was no help. Pat at RC lipos came up with an off the shelf simple solution. Thanks Pat
