parallell chargeing ??
  • Gen
    • Dec 2010
    • 130
    do many of you guys parallell charge
    i want to cause when i go out with 3 boats for the day with 20 packs or more its such a pain going to charger 20 + times to keep restarting packs ,
    now i have a hyperion EOSO610I.NET which is a 250 watt 10 amp charger ,and want to buy the parallell board below and dont mind if it takes a few hours ,and was also told is BETTER chargeing like this cause all packs will be charged similarly .??
    also if i want to charge 6 of 2s 5000 mah packs thats 30000 mah what should my max amps charge rate be 10 amps or do i need to be less ????
  • 785boats
    Wet Track Racing
    • 3423
    I often parallel charge but only a couple of packs at a time as my charger is only rated to 7 Amps.
    If you were to charge 6 x 5.0A packs in parallel with your charger at it's max 10 A setting, each pack would only be receiving about 1.5A charge rate. So they would take about 3 & a bit hours to charge.
    You need a bigger charger to do that. At least a 30A one, & a power supply to match.
    It's good for the batteries to charge them slowly, but not good if you need them in a hurry. But I see that you said you don't mind if it takes a few hours.
    Two packs would be the maximum on your charger to still achieve a 1C charge rate to each pack.
    All the best.
    Paul.
    • LiPo Power
      DJI Drone Advanced Pilot
      • 3678
      What power supply are you planning to use when you go out with all your lipo's and where is it going to be plugged in?
      Canada
      • Gen
        • Dec 2010
        • 130
        i charge everything at home ,then take charged batts out to lake ,,also what brands are bigger 20 or 30 amp chargers as new hyperion is only 300 watts as well
        • LiPo Power
          • 3678
          Got it, thanks.
          What power supply are you using at home?
          Canada
          • Gen
            • Dec 2010
            • 130
            16 volt 27 amps .ebay type ..runs good
            • Mel279
              • Dec 2008
              • 873
              I use that parallel charging board on my Imax b6 charger, its work fantastic...I use it to charge my 2 6s 30c 5000mah zippy and it balanced perfectly and it save me alot of times since usually I charge each packs. Now I don't have to bought a charger that can charger 4 packs at a time, use this board would be enough and even can charge 6 packs in one go.
              • Gunny
                Zombie Hunter
                • Feb 2011
                • 77
                I have one of those boards, and every time I use it to charge 2 lipo batteries it only charges them to 8.30v. Never gets them to the 8.40. Maybe mines a fluke board, who knows.
                A bizarre incident in the outskirts of an American suburb. It was later revealed the disaster was caused by the T-Virus. A mutagentic toxin created by Umbrella Incorporated for use in bio-weapon experiments. Don't worry the zombies are looking for brains, you're safe.
                • Gunny
                  Zombie Hunter
                  • Feb 2011
                  • 77
                  Also, when I was charging them I was doing a balance charge. I just got back from running the boat and am currently charging two batteries with that board in just a regular charge(no balance) to see if it gets them to the 8.4 mark.
