lipo nano-tech is the charger the same?
  • pyroM!KE
    • 379
    So if I get the nano-tech's, do they charge the same as regular lipo's??
    Charger settings????????
    Yes I am a newb..
  • larryrose11
    • Jun 2010
    • 768
    Cell chemistry is what determines the charging profile and final voltage. Lithium Polymer (LiPo) are different than Lithium Iron Phosphate (LiFe).
    Lithium Polymer (LiPo) have a max cell voltage of 4.2V. The LiPo NanoTec have a slightly different formation to allow the electrolyte to have a greater ion density. This leads to a lower internal resistance, or less voltage sag under load. The cells are otherwise the same. The charger should be fine. Just obey the manufactures max charging rate.
    Not so with LiFe. they have a MAX cell voltage of 3.6V. and need a charger that will provide that. Otherwise, you will cook your battery.
    A final note about battery life coming from a guy with professional battery experience (Ford HEV / EV)
    If your concerned about battery life, never discharge your battery all the way down to 3v, unless you are going to put them on the charger right a way, like within minuets. Same thing with charge. Never bring them up to full, unless you plan on using them right away, like in minuets. Time spent at full voltage, especially warm, is the fastest way to kill your batteries, outside of abuse.
    • sailr
      • 7128
      In a word, YES. Nano-tech is just a buzz word for latest generation of Lipos. You can charge them at a higher rate. Otherwise, charge the same as other lipos.
      Mini Cat Racing USA
      www.minicatracingusa.com
        • 9481
        and my Nano's say on the pack upto 5C charging rate
        • dana
          • Mar 2010
          • 3660
          so the nanos are the way to go these days..?
          • JPriami
            N4FOX
            • 1711
            I have a skycharger and it seems to do it all
            • LarrysDrifter
              Big Booty Daddy
              • 3416
              You can charge them faster than regular lipos,but Id just stick to 1c as that will give the longest battery life.I think the nano techs can be charged at up to 5c.
