Lets See If I Finally Get All This
  • gizmo1
    • Dec 2010
    • 272
    I think i finally may have a handle on all of this...Please let me know if i am wrong on any of it...
    Motor KV Rating 1800KV
    Example 1 : 14.8v = 4S , 14.8 x 1800 = 26,640 = prop speed ( RPM )
    Example 2 : 18.5v = 5S , 18.5 x 1800 = 33,300 = prop speed ( RPM )
    Battery Formula
    4S2P 5000 mah 40c = 14.8v 10,000 mah 40C, so 10.0 ah x 40C = 400 amps
    400. x .80 = 320 so in theory my CC240LV ESC is good to go,correct ?
    5S2P 5000 mah 40C = 18.5V 10,000 mah 40C, so 10.0 ah X 40C = 400 amps( still )
    400. x .80 = 320
    So if i have all of this correct
    KV rating and Battery voltage = approx. prop speed ( RPM vs motor RPM capacity )
    Mah = approx run time
    C Rating = discharge rate
    Now what is still confusing me is the 320 amp draw on a 240 esc, i am sure someone has the math for that to help my country a$$ get my head around it..
    Thanks for being patient with a noob.
    Giz.
    JAE21 Rigger, ML Boatworks PS 295 Tunnel , TS3 FE Tunnel , H & M No Step 3 Mono , H & M Skater , Wildcat EP , Rio EP .
    • 7512
    Your KV/ RPM calculations are correct,,,,Just remember that the calculated RPM is unloaded.
    Still going through the rest.
      • 7512
      C rating = discharge rate....correct
        • 7512
        Mah = approx run time,,,,,,kinda correct.....Mah is more like your gas tank capacity...the more you have the longer you can run.
        • jac4412
          FE Addict
          • Jun 2010
          • 427
          The 320 amp is what your batteries can supply... since your esc and motor will require less than that, youre good to go
          JAC4412 RC
          • gizmo1
            • Dec 2010
            • 272
            As you can see our conversations have paid off..Lol
            back to the ESC deal though , show me an example of what would get me in trouble on the 240LV esc...then i should have it down..
            thanks man,
            Giz.
            • johnf
              • Dec 2009
              • 1086
              Assuming the esc made it to ya huh bud?
              Also, prop selection and the ride attitude will affect amp draw for any given setup. Run wet and amp draw goes up. Bigger props do the same.
              Catching Air!
              • johnf
                • Dec 2009
                • 1086
                What hull are you planning on running this in? The tunnel?
                Catching Air!
                • jac4412
                  FE Addict
                  • Jun 2010
                  • 427
                  4S2P 5000 mah 20c = 14.8v 10,000 mah 40C, so 10.0 ah x 20C = 200 amps
                  400. x .80 = 160 = badddd. When youre ESC is all the way open pulling 240 amps or whatever... your setup won't be able to supply that... will strain the packs... overheat them... and melt through your hull
                  JAC4412 RC
                  • gizmo1
                    • Dec 2010
                    • 272
                    Man i am sorry i forgot to let you know it showed up..It showed up !!
                    Yes this will be on the tunnel...
                    • johnf
                      • Dec 2009
                      • 1086
                      Good deal! Mike could probably give you an idea on the amp draw for your setup. He ran the same motor too right? Amp draw will also vary with hull design.
                      Catching Air!
                      • gizmo1
                        • Dec 2010
                        • 272
                        Ok looking at that,my math is actually wrong in the 1st post
                        4S2P 5000mah 40C=14.8v 10,000mah 80C, 10.0 x 40C = 400 amp still
                        But in my post it should have been 800. x .80 = 640 ?
                        in my 1st post i did not double the 40C or double the amps x .80...
                        lmk if thats correct..
                        thanks
                        • johnf
                          • Dec 2009
                          • 1086
                          C rating doesn't double.
                          Catching Air!
                          • gizmo1
                            • Dec 2010
                            • 272
                            Thats what i thought, but i do double the amps correct ?
                            • gizmo1
                              • Dec 2010
                              • 272
                              Nevermind i figured it out, in my 1st post it was all correct, my buddy jac must have meant 200. x .80 to 160amps...because 400. x .80 = 320...
                              By no means am i throwing you under the bus amigo i just a bit confused when i saw that, i really appreciate all your help ...
                              thanks to all,
                              Giz.
