charging batteries together
  • roadrashracing
    • 1630
    I have a two battery boat and only one charger, I run stock packs and lipos. My charger only charges lipos up to three amps so basiclly I can charge my lipos in 3 hours for 5-6 min of run time. I am charging my batteries the day before. I know I need a another charger but I am still paying off the upgrades on my boat. Can you charge the batteries together in paraell if a make an adaptor?
  • domp444
    • Jul 2009
    • 901
    You should get a new cha-- Oh, oops! Haha
    Even if you make a parallel adapter, it won't take you any less time to charge them with just 3 amps of power. If you charge one 5000mah lipo in 3 hours, then in parallel it'll charge a 10,000mah lipo in 6 hours. If your charger went up to 6 amps then you could charge your 2 5000mah lipos in 3 hours.
    Am I making any sense here? Haha.
    Bottom line is you should look into a better charger when the money comes up. I use an iCharger 206b, and it goes up to 20amps with the P350 power supply. I can parallel charge up to 6 lipos with the parallel charging and balancing cables. And it takes about 1 1/2 hours.
    SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y's
    • sanyijr
      • 377
      Parallel charging
      Do a search on parallel charging. You can charge them together, but depending on you batteries and charger/balancer, there are limitations. I have set up my Triton Jr and Equinox to charge two large lipos. Obviously, by charger can only charge at 50 watts max, but it still makes a huge improvement in overall charging time... If this isn't enough direction, be more specific with your equipment and we can focus a bit more on the details....
      Sanyi
      • sailr
        • 7128
        You need one of these! Great charger. Great price! Free shipping!
        I have six chargers. Two of them cost over $200 each. I find myself using the one in the link more than the others!
        Mini Cat Racing USA
        www.minicatracingusa.com
