2 Batts, 2 ESCs, 1 reciever
  • ScarabChris
    • Oct 2010
    • 812
    Setting up a twin electric boat. I have two batteries, two ESCs and one receiver. I planned to use a servo splitter so I can control both motors simultaneously.
    I am powering the receiver with the ESCs. My concern is this. Will combining both ESCs with the splitter double the input voltage to the receiver and fry it?
  • sailr
    • 7128
    In a word, YES! I would highly recommend disabling the BEC's in both ESC's and adding an onboard battery for the receiver/servo. As an alternative, on twin motor setups in airplanes, the BEC of ONE of the esc's is disabled when using a Y connector to the throttle channel of the receiver. Only ONE BEC is needed to run the receiver and servo.
    Mini Cat Racing USA
    www.minicatracingusa.com
    • JMSCARD
      • Mar 2010
      • 4174
      YES I agree 100% with what sailr said... just disable both bec's and run a rxr pack.... you will have alot less heartache......
      • eboat
        • 726
        Would not just pulling the red wire out of the plug that goes to one reciever work ?
        It would be alot easier in his light duty scale boat he is building
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3784
          Red wire from ESC A cannot touch red wire from ESC B. So red wire needs to be disconnected on either A or B on the ESC or Y splitter before the join.
          • ScarabChris
            • Oct 2010
            • 812
            Ok that was my question. So just cut the red wire going to the receiver from one of the ESCs?
            These are the ESCs I'm using. They have a built in switch also.
            http://www.offshoreelectrics.com/pro...rod=dh-prb2314
            • eboat
              • 726
              That is what I said take the red wire out that goes to one ESC
              • ScarabChris
                • Oct 2010
                • 812
                These ESCs have brown-red-orange wires. So take out the red (center) of one of the ESCs?
                • FighterCat57
                  "The" Fighter Cat
                  • Apr 2010
                  • 3784
                  Yep. Center Red of one ESC.
                  • ScarabChris
                    • Oct 2010
                    • 812
                    Perfect, thanks guys! I didn't want to have to carry another battery in the boat.
                    Making progress on the build, check for updates in the boat building thread within the next day or so.
