Is this true when charging Batterys?
  • agressive1
    • Feb 2010
    • 89
    Hello
    I here that if your running 6s2p and you have to charge your batterys seperately that both packs have to be charged for the same amount of time or else when they are in use you can wreck your cells,is this true?
    Also i have the Swallow EQ charger and it can only charge 6000mah maximium will it not charge the two packs at once if i connect them in parallel. I guess i cant balance them at the same time though.?
    Thanks
    Dean
  • mappo
    • Feb 2010
    • 487
    Originally posted by agressive1 View Post
    Hello
    Thanks
    Dean
    Hey if you have separate packs, all you have to do is charge and balance. and you will get the same pack voltage unless if you have a Hyperion dual charger then you can balance and charge both at the same time in synchronous mode. iow. you can charge 1 pack at 1c and the other at 2c both will arrive at the same cutoff voltage.except 1 will take longer to full charge.you cannot charge in parallel unless using hyperion duo 2 or 3 "synchronous"
    Do you know what the biggest problem with the world is?
    That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
    • agressive1
      • Feb 2010
      • 89
      Thanks mate, i just heard something different thats all
      • 785boats
        Wet Track Racing
        • 3169
        You can parallel charge packs off one charger & you can balance them too. I do it with some of my packs often.
        Here's a bit of background on it all. Have a good read.
        NOTE: Only do it if you feel confident with all aspects of lipo charging.
        Cheers.
        Paul.
