Do what I say, not what I do
  • BHChieftain
    Fast Electric Addict
    • 2051
    So Chris and I are setting up our boats at the lake getting ready for a sprint. We get on the topic of connectors...
    ME:
    "So Chris, one problem with running bullets like I have is that sometimes guys inadvertently short out their lipos when hooking them up in series"
    BLAM!
    CHRIS:
    "You mean like that?"
    Here's the connector after just a split second short. I think I'll change my connection order to prevent this in the future-- I was connecting the two lipos together first, then connecting the lipos to the ESC (here is where I ended up connecting the other lipo leads together...).
    If I first connect the red lipo lead to the ESC then I can't end up with a short...
    Back to the soldering iron...
    -Chief
  • supafastsupra2
    • 103
    I shorted out an 8s setup on a buggy conversion before. The bullet connector literally disintegrated, nothing left.
    • Jeepers
      • May 2007
      • 2050
      thats what a "few" amps will do to you!!!
      been there done that a couple of times, it sucks!
      • egneg
        • 4759
        Did it yesterday and killed a cell on a 2S Elite 35C/5000. This really bummed me out as the pair was perfect for the UL-1 and I can't find a replacement.
        IMPBA 20481S D-12
        • ED66677
          • 1300
          use Deans!
          Emmanuel
          • kookie_guy
            • 900
            wow, that's pretty crazy.
            The way to posted is the way I connect mine in my BJ26.
            ESC red wire to one pack
            ESC black wire to other pack
            Jumper across the packs last
            • BHChieftain
              • 2051
              That'll keep you from shorting. The reason I don't like to do the jumper across the packs last is I get a pretty big spark that way. I like to connect the negtive lipo to the neg ESC as the last connection-- gets the most resistance before the final connection and the lowest spark.
              Anyway, now I connect the positive lipo to the positive ESC as the first connection which should keep me out of trouble...
              -Chief
              • forescott
                Hopelessly Addicted to RC
                • 3009
                How come I dont see any of you guys using ec-5 connectors. They are rated for 120 amps, and are made for dummies like me!
                • BHChieftain
                  • 2051
                  Ohh, I'm liken' that idea!
                  • Chilli
                    • 3204
                    I do the female bullet on the battery positive lead, male on the negative like many of us do, but still screwed up every once in a while. Thats because I always used black shrink wrap on all the connectors. As soon as I went to the red shrink on the positive leads, black on negative (controller and battery) I have never gotten close to a short.
                    Mike Chirillo
                    www.capitolrcmodelboats.com
                    • DINO7
                      • Jan 2009
                      • 165
                      EC5 5mm connectors for me too..no heat and tight fit with no mistakes on hooking batts...
                      H&M Intruder S twin Leopard 36/74/3270 @ 3S-HIFEI 200A
                      MHZ mystic 114-TP4050 5D-HIFEI 240A hv ESC- @ 2 x 5S
                      BANDIT S"love boat" LEHNER POWERED.. RCFASTBOATS.GR MINI COOPER CAT
                      • 785boats
                        Wet Track Racing
                        • 3423
                        I have a hydro where the batteries (2 x 2s) are right up under the front cowling & I have to reach up under there to plug the leads into the ESC. It's hard to see up there with my hands in the way. Once, after thinking I had hold of the red from one pack & the black of the other (to link them in series) I soon found out when I tried to plug them in that they were both from the same pack.
                        Just like you Chief, I was talking to someone at the time instead of paying attention to matters at hand.
                        Luckily the battery survived, as only the edges of the connectors touched but I had to replace both connectors. It was a tense 15 minutes waiting to see if the pack was going to swell or not.
                        Cheers.
                        Paul.
                        • JMSCARD
                          • Mar 2010
                          • 4174
                          I found the easiest way to keep from shorting out your connectors is just totally "slowing down" during the connection process.... the bullets are fantastically easy to use as long as you take the time to use them properly... I too have shorted my connectors... but after a couple times you tend to pay a little better attention:) keep the bullets....
                          ME:
                          BLAM!
                          CHRIS:
                          -Chief
                          • sailr
                            • 7128
                            I think we have all done it at least once. My solution now is to pay attention. Don't be distracted! I agree that the pos/neg to the esc hooked up first is the best when running series!
                            Mini Cat Racing USA
                            www.minicatracingusa.com
                            • bigwaveohs
                              • 606
                              Those are what I use in my VS-1 and couldn't be happier!
                              I let the dogs out...
