Balancer or Not when charging???
  • LiPo Power
    DJI Drone Advanced Pilot
    • 3678
    Picture of it at post # 1
    Originally posted by egneg View Post
    I always use a balancer when charging. What charger are you using - I had a Triton that took a long time but since I started using a Hyperion Duo it is 30 minutes or less.
    Canada
    • egneg
      • 4759
      At .1 amps it will take a long time. The HD ramps up to 5 amps.
      IMPBA 20481S D-12
      • line6
        • 510
        I think he said he is charging at 5amps
        • AndyKunz
          • Sep 2008
          • 1443
          My chargers (FMA Cellpro 4S) only charge my lipo's in balance mode. It could be that you had a low cell, and it did a safety charge to bring it up to the others. Balancing chargers will only tolerate so much of an out-of-balance condition during charge. The .1A rate is typical for an early balancing stage. It could be that your high-current charge rate is set too low, making it take too long to get to balancing.
          I would discharge the pack and try again. Watch it and make sure you're getting a 1C charge rate near the beginning (mine starts slow, increases to max current, and then goes into max voltage then balance).
          Andy
          Spektrum Development Team
          • Jeff Wohlt
            • 2740
            I do not balance and certainly not 2S all the time. I charge them and then use my blinky to bring them back to balance. When I balance with my blinky it takes longer. It cut charge to the higher cell.
            www.rcraceboat.com
            jwohlt5362@yahoo.com
            • LiPo Power
              • 3678
              That is great info folks, thanks. Charging using my Equinox balancer in interface mode with charger set up to normal LiPo charge, they get the juice way faster than straight from charger using LiPo balance mode. Did this testing while back today and that is what I got.
              Canada
              • LiPo Power
                • 3678
                Hi Jeff
                What blinky are you reffering to please?
                Robert
                Canada
                • Jeff Wohlt
                  • 2740
                  Sorry, Astro Blinky...it is a great thing to have.
                  www.rcraceboat.com
                  • CornelP
                    • 793
                    At 5 amps, you should have the charge ready a lot faster... I chrge with equalizer on every time, and the only pack that gives me grief is one that my son managed to short... takes ages to equalize, just like yours. The other identical pack charges in 20% of the time. Check the voltages on the individual cells before charging, you might have a surprise...
                    • ozzie-crawl
                      • Sep 2008
                      • 2943
                      well here is my input, i used to always balance charge until i was talking to a guy who repairs batteries for a living,he goes to different battery conventions and what not, he told me that lipo manufacturers told him worse thing to do is balance charge lipo cells all the time. now i dont know if that was true or why they would say such a thing but since then i have just charged my packs not balance charged them. they only time i balance them is if i have had them stored at 60% for a period or if the cells show more than .02 of a volt difference.
                      i only use 2s packs and cant remember the last time i balance charged them as there always with in .01 of a volt,also i never run my batteries to lvc
                      • LiPo Power
                        • 3678
                        This is cool...., thanks
                        http://www3.towerhobbies.com/cgi-bin...inky&search=Go
                        Canada
                        • 785boats
                          Wet Track Racing
                          • 3423
                          LiPo Power
                          I have one pack that does that. The Charger doesn't sense that it is full, even though the current is down to 0.1A & the voltages of each cell are up to 4.2V & if you watch the Mah readout, no more Mah's are being put into the pack. The charger will stay running until the timer cuts out. I've watched it & the pack was fully charged after about one hour.
                          I now use the Fast Charge cycle & the charger cuts out when the pack is charged & balanced.
                          The Fast charge mode just cuts out when the charge current drops to about 0.5A instead of 0.1A. This is where the time is saved (under normal circumstances) as its not taking 15 or so minutes to put that last 50-100 milliamps into the pack. With a pack that won't trigger the cutout in the normal balance mode, however, it senses that the pack is full & cuts out. At least it does with mine.
                          I often use the Fast Charge mode on all my good packs too. Lets face it the extra 100ma or so aren't used anyway.
                          I'm sure your charger has a Fast Charge mode. All you can do is try.
                          Cheers.
                          Paul.
                          • line6
                            • 510
                            LiPo Power
                            Cheers.
                            Paul.
                            Very well put makes perfect sense to me.
                            • LiPo Power
                              • 3678
                              Thanks Paul.
                              I will try this out next time.
                              Robert
                              LiPo Power
                              Cheers.
                              Paul.
                              Canada
