zippy flightmax or turnigy ?
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    I've been really happy with the Zippy Flightmax 30/40 C 5000 4S batteries; used singly in my P-Spec OPC with UL-1 motor. Great punch so far. I want to order another pair for sport running at 4S2P in my Vegas [ 1515 1Y ] . Any advice on choosing between:
    Zippy Flightmax - 30/40 C , 526 g , 140 X 48 X 33 mm, $ 79.02
    Turnigy - 30/40 C , 537 g , 143 X 49 X 32 mm, $ 64.95
    Apparantly they're not the same batteries ; the Turnigys seem larger, but less $$.
    Any advice/feedback ?
    Edit : I'm running a conservative setup propwise in the Vegas, sport running so far, short runtimes. Mr. Hill, you have any input, you're our battery knowledge guy ?
  • Raydee
    • 1619
    I ran the Flightmax cells in my 6s heli and they were good cells for the money. I have been reading that some of the Turnigy cells have been way out of balance and others are puffing. They have sold so many of those cells that you really can't go by some guys complaining about a bad pack here and there. For the money they are worth a go in a mild setup for sure. I was going to buy 4 packs for my heli and decided to go with G3 packs just to keep all my packs the same and the fact that when I needed them the Turnigy packs I wanted were out of stock for almost a month.
    Team Liquid Dash
    • yurkanip
      • Jul 2008
      • 495
      Chopper, I have used zippy's since I started in boats a few years ago, and used mainly zippy-H. I have the Turnigy 4s (5.0) batteries and they are great. As most zippy's they all have great punch..especially the higher c rated lipos that they sell now. I have never used flightmax and have read mixed reviews on them, but I have read that the turnigy are the same as the zippy-H. Zippy-H were/are supposedly the best in the zippy lineup. The Turnigy that I use, both in 2650 and 5000mah are compact, but thick. They fit in my .21 riggers great, and the size is fairly accurate to what hobbycity claims.
      Hope this helps.
      • Raydee
        • 1619
        Did you buy all the 6s2650 packs that I was trying to order?
        Team Liquid Dash
        • yurkanip
          • Jul 2008
          • 495
          Ha, Ray...no I bought the 2650's in 4s.
          • properchopper
            • 7708
            Thanks Guys. Headin' to the lake, I'll check in later & see what the consensus is
            • yurkanip
              • Jul 2008
              • 495
              Chopper....take some vid of your miss vegas, if you can. I'd still like to see it run. Mine should be finished in a few weeks, as well.
              • bustitup
                • 3072
                I thought the turnigy's were zippy's newest batts and flightmax has 4mm bullets and turnigy has 5.5 bullets and heavier gauge wire
                I just received two 6s 30c 5000mah turnigy's for my sprint cat
                Thank the good lord Zippy has made rc brush less lipo's a reality for new users wanting to get into the FE world ...it just helps the sport to have more people envoled to force manufactures to develop better products that are more competitive
                killer products and killer performance......how many times have I heard reviews of how these batts compare to the kingpin enerland cells
                • Simon.O.
                  • Oct 2007
                  • 1611
                  I can't comment on the 4S pack, but I can compare the 2S packs
                  I have a 5000mAh 20C Zippy and a 5000mAh 20-30C turnigy.
                  The Turnigy is a little bigger, has heavier softer leads and has way more punch.
                  It is cheaper and for me is the better buy.
                  btw the Rhino 4S 4900mAh pack I have is close to identical to the Polyquest in size, shape and weight. ???
                  Makes you wonder.
                  For sport boats you can not miss with the Turnigy.
                  • Tony
                    • 420
                    I have both ZippyFlightmax 2S 4000mAh, and Turnigy 6S 5000mAh lipos. They work fine just like my other more expensive TP packs.
                    • properchopper
                      • 7708
                      [QUOTE=bustitup;118458]flightmax has 4mm bullets and turnigy has 5.5 bullets and heavier gauge wire
                      Actually the 4S 5000 Turnigy's have 4mm power leads but no biggie, I have lots of 5mm to solder on.
                      It seems like I'll go with the Turnigy's based on what's been said so far. I will say that my 4S 30C 5000 Zips have enormous punch for the first 30 seconds or so; my VS-1 can't stay level for 30 seconds and then settles down and rips.
                      Thanks all for the comments
                      • properchopper
                        • 7708
                        Patrick, my new camcorder got ripped a few months ago. I'll see if Jan can shoot some footage. With some really tired batteries & small props [for the 1515 1Y] the boat is so perfect I'm just floored. Just beautiful to see and run [ I even put the wing on for looks !
                        • 6S HYDRO
                          • 1325
                          i got the 5.0 turnigy 4s and it awsome- way better than the flightmax w/ the 12ga wires. and the newer higher c turnigy's have crazy 8 ga wires
                          • properchopper
                            • 7708
                            Just ordered some ; with my discount; $ 62.50 ea. ! BTW Paul, I'm planning to make the Oct. 27 race in AZ; You be there ?
                            • 6S HYDRO
                              • 1325
                              yes i will, maybe you can help me some w/ my vs1- setup
