Looks pretty sweet when its done...
Whiplash Sport 20 FE Build
Paul, is it a P-Spec H-5 you need the specs on ?Originally posted by 6S HYDRO View Postwhat was modified on the h5 lucky?2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
I'm running the centerline of the strut parallel to the bottom of the sponson. Start out with ZERO angle. Use an M445 prop if running spec.Mini Cat Racing USA
www.minicatracingusa.com
So about 1/2-3/4 inch to the centreline of the strut ????/
M445, is this slightly overpropped ? i was thinking more a X442 or a Grim 42-55 , i know everyone has their own favourites here .
the 'M' in front of the numbers means Modified right??
Thanks again
Mine is slightly different, since I modded the sponsons to be 1/8" deeper I run it flat with the sponsons, at about 3/4" deep.
The M445 will NOT overprop the boat if you run the strut correctly. All of us here are running that prop on our Whiplash'sMini Cat Racing USA
