Whiplash Sport 20 FE Build
  • teach
    • 509
    #136
    Did you have any issues with mounting the pushrod seals on the inside? Looks like a very clean idea if it holds up well.
    • LuckyDuc
      Team Ducati Racing
      • Dec 2008
      • 1058
      #137
      No issues. I haven't had a drop of water in the hull.
      • crabstick
        • Jul 2008
        • 955
        #138
        I do all my boats that way too, works well. Boat is dry
        Matt.
        www.rcboats.co.nz
          #139
          I'm consuming between 3000 and 3400mAh now, with low voltage reaching 13.5v... even with my Thunder Power 5000mAh 45c packs....The other whiplash racer in my heats was running a slightly more aggressive prop and experienced a ESC thermal shutdown in the 3rd heat.
          No wonder, you are propped for 85-90+ amps. The average amp draw value on the datalogger is for the entire time the motor is running, including time at very low throttle. A look at the log clearly shows a pretty steady 85-90 amps with a few higher peaks and lower valleys while actually racing. If the actual racing time was 140 seconds - 18 seconds a lap for 6 laps and 30 for the 7th lap, that's an actual average draw of almost 90 amps during racing, based on milliamps consumed.
          Your boat is not too far behind a P Sport Hydro in power consumption - my 1521/1.5D-powered sport boat uses about 4500 mAh for a full mile race. Our club LSH boats use about 2500 mAh for the same race lengths, with top speeds around 50.....
          • DPeterson
            • 991
            #140
            My Whiplash, the other whip Sean refers to is using 2200 - 2400 mah per heat. The boat is fast and I think there is more to come.
            The heat where the boat was noticably faster ended up thermoing the bec circuit. I learned once again not to rely on the esc bec. Everything is now switched over.
            This weekend I will run the whip with the higher pitch prop to see what happens. Crossing my fingers.
            Doug
            Doug Peterson
            IMPBA 19993
            www.badgerboaters.com
            • detox
              • 2357
              #141
              Have you tried the new ABC 1518/3 blade? This prop is a hoss in my UL-1.
              Just started my Whiplash build BTW
              • LuckyDuc
                Team Ducati Racing
                • Dec 2008
                • 1058
                #142
                Doug,
                Are you sure that you are only consuming 2200-2400 mAh? That seems low. Did you do any more testing this weekend?
                • LuckyDuc
                  Team Ducati Racing
                  • Dec 2008
                  • 1058
                  #143
                  Any idea on the amps you are pulling with the ABC 1518/3?
                  Keep us posted on the whip progress.
                  • sailr
                    • Nov 2007
                    • 7128
                    #144
                    2400mAh for a heat is about right with the right prop.
                    Mini Cat Racing USA
                    www.minicatracingusa.com
                    • DPeterson
                      • 991
                      #145
                      Sean
                      Had to abort the testing this weekend. Pond weeds. We are now focused on weed cutting for the next couple weeks so we can run our race.
                      I am very sure on the 2400 mah for the Whip.
                      Doug
                      Doug Peterson
                      IMPBA 19993
                      • LuckyDuc
                        Team Ducati Racing
                        • Dec 2008
                        • 1058
                        #146
                        One thing that comes to mind is that I typically run 9 laps per heat. I do 2 full mill laps prior to the buzzer, and our club makes us run an additional full lap after crossing the finish line. That might account for the extra consumption I'm seeing.
                        The math works out. 3100mAh / 9 laps = 344mAhs per lap.
                        If I was to do 7 laps (1 mill lap with 6 heat laps) I would be right at 2400mAhs.
                        • detox
                          • 2357
                          #147
                          I have no idea. I do have Eagletree, but have not used it with this prop. I was simply bolting on different props then visually checking speed. UL-1 was faster and unstable as usual.
                          Currently weeds are a problem in my pond.
                          • detox
                            • 2357
                            #148
                            I believe the UL- hatch and nose piece will work on the Whiplash, but I will be using the ML boatworks hatch.
                              • 9481
                              #149
                              will these packs fit in this hull?
                              thanks
                              • Jeepers
                                • May 2007
                                • 2050
                                #150
                                They should fit just fine I carry 2x 2s 6500mah packs in my Whip 20.
