Mean Machine Catamaran (Sport)
  • Scott T
    replied
    Originally posted by toysRme View Post
    Just got my hull from OSE and want to the same info???
    intended setup
    seaking 180A
    Feiago 9xl
    zippy 4s 5000 30c
    x440
    speedmaster hardware mono strut and 5.5 inch rudder
    any input would be appreciated
    My rudder is just inside the edge of the right sponson. Seems to work very well. Pics in this thread - http://forums.offshoreelectrics.com/...ghlight=aussie
    You should be able to bump up to an X442 and maybe even an M445 with that set up, but start with the X440 and see how she goes!
    Leave a comment:
  • rawsonreyes
    replied
    new mm setup
    hi guys the whole thread got some great setups but has anyone try the 580motors from steven. i have got an 90amps quickworldwide.com esc starts at 6s can this setup be eff, props x440/442/447 i do my own prop mods/ s/b/det also cupping. speedmaster strut/5"rudder.could this range give 50-60mph.rreyes.
    Leave a comment:
  • toysRme
    replied
    Originally posted by Nautiboyz View Post
    Guys, What rudder offset are you running with the speedmaster hardware???
    Thanks!
    intended setup
    seaking 180A
    Feiago 9xl
    zippy 4s 5000 30c
    x440
    Leave a comment:
  • obrien
    replied
    my guess would be mid to upper 40mph range
    Leave a comment:
    replied
    what speeds should a MM get using 4s on a 8XL ?
    thanks, I love my MM !
    Leave a comment:
  • Mel279
    replied
    Originally posted by bustitup View Post
    Well on rc cars this how you figure it
    There are 3,7 volts per cell so. A 6s lipo has 22.2 volts
    So to figure cut off take the number of cells x 3.2 so in you case 3.2 x 6. = 19.2 would be the safe cut off
    Hey bustitup, thanks for the info regarding the cut off
    Leave a comment:
  • bustitup
    replied
    Originally posted by Mel279 View Post
    Hey thanks, what cutoff voltage should I set on hydra 240 if Im using 6s?with 12xl motor, can I reach 60mph on that?
    Leave a comment:
  • calcagno45
    replied
    Mel: I would stick with the Octura X and M props. Those CNC props are pretty unchartered territories compared to the tried and true ability of the Octuras.
    As far as the voltage cutoff on the Hydra, most people will set them anywhere from 3.0-3.3v per cell. Never go below that 3.0v per cell.
    Sewerpit: I would try a X440 or X440/3 to start. Make sure everything is good and then start propping up. Another nice prop on the MM is the Y537/3. good speed and drops the amps.
    Leave a comment:
  • sewerpit
    replied
    mr fluid
    great info, maybe you can help me a bit with props, there are so many people using diff set ups with good results and it can get confusing . i will be running my mm with an 8xl ,hydra 120 esc on 4s2p what props should i be looking at for sport and then for speed thanks for your input MR.watts your input would be great too thanks
    Leave a comment:
  • DISAR
    replied
    As you understand unless you use a motor that it has been run and tested by someone and then by somebody else you will not get many answers to your questions.
    Testing is the best thing you can do taking the risks ofcourse. My proposals are based on estimations and calculations and where you can start. Start with the smaller propeller and when everything is cool start going to bigger ones.
    Leave a comment:
  • DISAR
    replied
    whats the difference a m or x prop.....is this info all on the 1512 motor?
    The info I gave you is based on your motor and not mine.
    Leave a comment:
  • Mel279
    replied
    3657/4 is 36mm in diameter, 57mm pitch.
    3857/4 is 38mm in diameter, 57mm pitch.
    3861/4 is 38mm in diameter, 61mm pitch.
    I got the info from OSE store
    Is this prop suitable for mean machine with 6s setup?
    Leave a comment:
  • Mel279
    replied
    Originally posted by calcagno45 View Post
    12xl should be great on 6s!
    Leave a comment:
  • calcagno45
    replied
    Leave a comment:
  • Mel279
    replied
    You will blow your ESC if you try to run 6S on a 1512/2D with an m645. Those props and speed suggestions cannot be for anything but a calculator.
    Your 1515/2.5D motor is really too much for 6S except for racing. It would work fine on 4S but 60 mph is out of the question. Run an x445 for sport and an m545 or m645 for speeds in the 45-50 mph range on 4S. If you want more speed you'll have to get a different motor for either 4S or 6S, unless you enjoy buying ESCs regularly.
    The 'M' series props are just like the 'X' series with the same number, except they have some blade area removed from the leading edge (tongue).
    Mr Jay, what motor should I use if I want to go for 6s?I've got feigao 12xl, is this ok?are there any device which could protect esc from blown or fried?
    Leave a comment:
