Miss Vegas FE conversion
  • nate
    • 1702
    #31
    Originally posted by detox View Post
    In my UL-1...I fried my Hydra 120 using Nue 1515 1y and m445 prop (60mph). Using the smaller m440 prop the Hydra 120 esc lived, but ran too hot 175 degrees (55mph). Maybe the Etti 150 would be OK...do not know? I would use the higher quality 35c Hyperion cells (especially using 4s1p) to be on the safe side. I do know that low discharging cells will kill an ESC.
    BTW... great job Properchopper
    Detox, gahhh. You got 60mph with an m445 on 4s. Nice!
    Id just go with a Hydra 120 keep the prop at an x442 or m440 as said, then you will see a High 40's boat and still be pretty fun light setup.
    LMT
    LehnerMotorenTechnik.com
    • Flying Scotsman
      Fast Electric Adict!
      • 5195
      #32
      Dean, what are you trying to achieve...speed....long run times?
      This is not a cheap hobby. So state your goals and be realistic.
      Douggie
      • bedrock
        • Aug 2009
        • 343
        #33
        Hi all
        Anybody tried the SEA KING 180amp ESC?????
        Noticed that they are cheaper than the Hydra ......
        Dean
        ________
        Suzuki intruder
        • bedrock
          • Aug 2009
          • 343
          #34
          Douggie
          Looking for Speed but run time of around 4mins approx
          Dean
          ________
          VOLCANO VAPORIZER
          • properchopper
            rcgoatbuild@snotmail.com
            • 7708
            #35
            Originally posted by bedrock View Post
            Douggie
            Dean
            Dean : Speed / runtime / budget price : Choose any TWO.
            To run 4 minutes at high speed you'll need some high quality batteries [ not cheap], a high efficiency motor [ not cheap] and a speed control with plenty of headroom - the Seaking 180 might do it, but plenty of watercooling [ a band-aid at best].
            • Ub Hauled
              • 3051
              #36
              Make sure that the SeaKing is not one of the recalled ones...
              • Flying Scotsman
                • 5195
                #37
                Douggie
                Dean
                Speed as other have mentioned comes at a cost, what is your budget and a long run time negates a truly fast boat on two passes
                Douggie
                • bedrock
                  • Aug 2009
                  • 343
                  #38
                  Hi guys
                  just picked up a 1521 1.5d can I run this in my Vegas conversion is very close to Properhopper
                  if so what batt's and prop?
                  im currently running a octura x442
                  thanks in advance
                  Dean
                  ________
                  Chrysler Aspen Specifications
                  • Ub Hauled
                    • 3051
                    #39
                    I use the 1515/1y in the Vegas, just like Tony... in my opinion, having the 1521.1.5d might be overkill... doable but overkill.
                    The 1515 is PLENTY of motor for that hull...
                    On the other hand, it might be a fun project, make sure that you reinforce the hull man... you'll need it.
                    • wolf IV
                      • 1050
                      #40
                      Wow perfect catch tony... Was wondering where your build thread was for this beuty!
                      http://www.youtube.com/watch?v=e-npTLBHefY
                      • properchopper
                        • 7708
                        #41
                        The 1521 1.5D is a great motor for 4S with a big prop. I run one in my DF 33 on 4S
                        5000 G3's as 2P with a Hydra 240. I can spin a X450/3 for a 2 min. heat + mill with nominal temps. Jay Turner runs this motor in a 33" Aeromarine P-Sport Hydro with good results. Put the 1521 1.5D in the 30" Vegas on 4S and any prop bigger than a 445 will likely give some bad outside sponson lift. A smaller prop on 5S should work, but 5S batt's are too tall to fit under the hull on the sides of the motor, where they should be to get the cg right. Jan's correct, the 1515 1Y is just right fore the Vegas on 4S. Sell your 1521 1.5D & get the Castle/Neu 1515 1y & you'll come out ahead money and performance-wise.
                        • Jeepers
                          • May 2007
                          • 2050
                          #42
                          Hi guys
                          thanks in advance
                          Dean
                          that motor can handle BIG props, like UB said, its probably overkill! I run that motor in a same size hull and turn 45 -50mm props with ease, on 4s1p 6500mah 35c lipos.
                          The X442 works great on a 1521 1.5d with a 12 cell Nimh set up. I ran an entire race season on that set up. though it did torture the cells,150 160 degrees after 1mile heat yikes! I threw a bunch cells away during the entire season. ( I tortured them on purpose)
                          • cybercrxt
                            • 2926
                            #43
                            Propper Tony,
                            You got me hooked, Im picking up a Vegas hull this weekend to do FE with. Its the same model as yours, not the deuce. I will probably put in a 180a turnigy I have, and a 36-70-2000kv Medusa since I have them laying around! Mike
                            • properchopper
                              • 7708
                              #44
                              Originally posted by cybercrxt View Post
                              Propper Tony,
                              Mike, you'll have miles of smiles with that boat. Give the wire drive with the ball bearing strut some thought, I really like mine.
                              • Ub Hauled
                                • 3051
                                #45
                                Propper Tony,
                                Just so you know, NEU is maintaining Medusa motors... great deal since Medusa is in a different part of the hobby now.
