Miss Vegas goes electric!
  • Jeepers
    • May 2007
    • 2050
    Here is my Miss Vegas conversion, I removed every thing except the original motor mounts. were the hole for the muffler exited the transom I made a wood backing and then mounted the new speed master rudder. I found that the stock rudder would hit the prop if it was any larger then the Y535. I had done this conversion before but due to the manufactures sunday build the hydro was problematic, the power of the brushless motor would flex the old stuffing tube so bad, that it would sound like blender chopping ice! So tonight I decided to start over, this conversion is all new and i am trying to use stuff I have just lying around. wish me luck!
  • Jeepers
    • May 2007
    • 2050
    Here I installed the steering servo using mahogany blocks. on the hatch I wanted to keep the turbine intakes open, so I used water proof epoxy and glass cloth to make a "shelf" to close up the hatch.
    • Jeepers
      • May 2007
      • 2050
      I closed up the hole were the old steering rod went. I also installed the motor mount and put two layers of 6 ounce glass cloth on it.
      • Jeepers
        • May 2007
        • 2050
        here i am instaling the new stuffing tube. I used a piece of brass tubing that would slip over the the motor shaft and glued it into place, i then shortened it and used smaller pieces of brass to reduce the ID and used lock tight to secure the smaller pieces in place. here is the motor with wire drive installed and a mahogany cradle to support the end of the brass tube.
        • avengersteve
          • 395
          nice! i may have to do that with mine, if i cant sell it in a couple days.
          restoring the collection
          • Doozie870
            • 970
            Burning the midnight oil eh.. looking good, are you planning that for p hydro?
            • saleens7
              • 1130
              cool....what motor you using?
              saleens7, the wookie of rc boating
              • Jeepers
                • May 2007
                • 2050
                yeah I will be having a couple of late nights for the next couple of weeks! Iam thinking more along the lines of a Q class hydro 18 cells or 6s packs but i will try it out on 12 cells first. she may be more impressive than i think. I should have her at the next RMTB race to mess around with!
                • Jeepers
                  • May 2007
                  • 2050
                  I am using a Neu 1521 1.5d that happened to be lying around! Its specs are 1860kv 1800 watts cont, 3000 watts peak for 30secs, on 12 cells it turns approx 26000 rpm, on 18cells approx 40,000rpm, sound like fun?!
                  • hammertime
                    • 517
                    this thing is going to be insaine
                    60% of the time... it works every time!
                    • Jeepers
                      • May 2007
                      • 2050
                      thats the plan :D :D
                      • Raydee
                        • 1619
                        Jeepers just wondering how the project is coming along? I am thinking about the same conversion soon.
                        Team Liquid Dash
                        • Diegoboy
                          • Mar 2007
                          • 7444
                          Here's a video of Dirtysouth31's Miss Vegas Brushless
                          Video
                          • Jeepers
                            • May 2007
                            • 2050
                            just about finished!!!! I am waiting on a 3/16 strut(couldnt find the other one), and I still have to glue the wire in the stub shaft. I will try to post some pics later on tonight! I think I will bypass 12cells and go directly to 18! It will have gps on board and if any one has a video cam next sat. a vid will be posted on OSE!
                            • Jeepers
                              • May 2007
                              • 2050
                              Video
                              HEY DIRTY! nice boat how fast does it go?
