Whip 20 Medusa 3670-1600 on 6s (Pics and Bad Video)
  • RPC1
    • Apr 2008
    • 125
    Finally got some pics. This is a Medusa 3670-1600(Love It) on 5000mAH Turnigy 6s Lipo, Turnigy 120 amp ESC, Octura V940 DT/S/B(Horrible). Before this run I ran the X642 DT/S/B and ran 54.7mph, electronics were barely warm, and I hit some rocks Threw the V940 in and it cavitated bad and planted the nose (too much lift) and only ran 48mph. The X642 was great, going to try an X645 next. Sorry about the vid, it is pretty bad along with some bad language.
  • RPC1
    • Apr 2008
    • 125
    More Pics, battered X642 and GPS reading with the x642 prior to the carnage.
      • 9481
      How bid is this boat?
      looks good!
      • Ub Hauled
        • 3051
        Originally posted by RPC1 View Post
        ....battered X642.
        Dude! Is that a prop or a flower??!?!?!?!
        There are a few ways to heal the too much lift problem, have the strut be completely neutral as far as angles go, move the CG a bit further back to put some weight on the prop... it should boogie.
        Watch the heat!
        Nice potential.
        • crabstick
          • 955
          I find with a lifting prop that a near to flat strut angle seems to work best, when running a non lifter i use about 2 deg of down angle on the strut
          Matt.
          www.rcboats.co.nz
          • RPC1
            • Apr 2008
            • 125
            I took the 2* out of the strut and set it to neutral, and put the GPS at the back of the boat, CoB is now 2" behind the sponson. I may try to put some cup in the prop to reduce lift, I would like to get this prop to work.
            • RPC1
              • Apr 2008
              • 125
              looks good!
              It is 30" long, probably 6-7lbs. The kit is made by Blazer Marine. I think I have around 40hrs into building it.
              • crabstick
                • 955
                I think the 940 should be ok with no cupping, that angle reduction should do the trick, if its still burying the nose then you can raise the strut depth a little.
                One change at a time though.
                Matt.
                www.rcboats.co.nz
                • crabstick
                  • 955
                  http://www.blazermarine.com/cart.php...t_detail&p=187
                  Just weighed my whip yesterday at 3.4kg or 7.2lbs RTR with Kb45 and 6s.
                  Matt.
                  www.rcboats.co.nz
                  • bigpapa
                    • Apr 2009
                    • 2531
                    ouch
                    hope boat is ok
                    THUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
                    CARBON FIBER MINICAT HYDRO,MINICAT HYDRO,PROBOAT MISS GEICO,SKUNKWORKS 32" CAT TWIN, H@M VIPER TURBINE ---JEFF WOHLT WIRE DRIVES
                    • nate
                      • 1702
                      http://www.youtube.com/watch?v=_Hc_m7HZA2c
                      Who makes this turn fin??
                      LMT
                      LehnerMotorenTechnik.com
                      • RPC1
                        • Apr 2008
                        • 125
                        It is the Kintec Racing turn fin for the UL-1. I cut about an inch off the rear portion.
                        • RPC1
                          • Apr 2008
                          • 125
                          Originally posted by bigpapa View Post
                          ouch
                          hope boat is ok
                          This is a tough boat. The impact bent the rudder almost 90*. Need a little epoxy on the sponson tips and glue it shut.
                          • calcagno45
                            • Mar 2008
                            • 1050
                            Any better pics of your complete setup inside?
                            • RPC1
                              • Apr 2008
                              • 125
                              I'll get better pics tonight. The bulkheads were all cut forward of the sponsons to accommodate the battery as far forward as the canopy will allow. The motor mount is a UL-1 (sucks-too weak). The tub is fully sheeted with 1/16" birch ply. From the sponsons back to the transom is air tight(more flotation).
