P-Mono build
  • sean450
    • 83
    P-Mono build
    Here is a few pics of my .21 mono that I'm converting over to electric. I got this hull from Jerry Dunlap many years ago when I lived in Wa. State. I don't even know who designed it. But anyway, so far I have glassed in new engine rails as the originals were in bad shape. I've manage to fill and sand out all the imperfections in the hull i.e., pin holes scratches etc. and sprayed on a couple coats of primer. I plan on running it with either a 9XL or maybe a Scorpion HK outrunner on 4s2p.
    Should receive the hardware in a few days. Only issue I'm having is how to make a waterproof cowl for the hull. I'll post more pics as the build continues. Any comments on motor choices would be appreciated. I plan on running this boat in some heat races with the local nitro club here in No. Va.
  • Diegoboy
    • Mar 2007
    • 7443
    Nice hull. Spank them gassers with one of their own hulls!
    What are the dimensions of the opening?
    • sean450
      • 83
      the opening approx. 12"x6".
      • sean450
        • 83
        I've seen guys use some clear plastic sheeting to close off the opening where their engines would usually sit.
        • HOTWATER
          • 2419
          Cut the lip off of the deck around the opening, epoxy some strips of 1/8"x1/2"wood under the opening leaving about a 1/4" showing for some plexi glass to sit on...then just tape the plexi down to seal...done! Cheap and easy fix!
          -Kent
          "Will race for cookies!"
          IMPBA D12
          My Gallery: http://forums.offshoreelectrics.com/album.php?u=1738
          • sean450
            • 83
            Thanks for the tip Kent. The build is coming along nicely. Added some extra glass to the hull floor and mounted the hardware. Next I'll be mounting the motor and mount and making the canopy. Will post more pics soon.
            • HOTWATER
              • 2419
              Great! I like the old School stuff!
              -Kent
              IMPBA D12
              • sean450
                • 83
                Is that aCrapshooter? If it is, nice boat. One of my favorites from my nitro racing days.
                • HOTWATER
                  • 2419
                  It's actually an Avenger/Spider - Avenger...Ahh the good ole glow days...
                  I think it's ready for a Nue motor now...what do you think?!
                  -Kent
                  IMPBA D12
                  • sean450
                    • 83
                    Why buy new when you can always convert your old nitro hull. I have a rigger that's based off of a Dumas Hawk .21 that I'll probably convert once I finish the mono.
                    • HOTWATER
                      • 2419
                      Man! I saw one of those that someone converted to FE on youtube or something and it left blisters on my eyelids!!LOL!! It was a red and blue one that i've seen tossed around the swap shop a few times...Very fast boat!!
                      -Kent
                      IMPBA D12
                      • sean450
                        • 83
                        Yeah I've seen that vid to. I have the front sponsons from the hawk but my fuselage is build longer for better handling. It made a nice heat racing boat. Very stable and turns really nice.
