Diegoboy's Stretch Renegade rigger
  • Diegoboy
    Administrator
    • Mar 2007
    • 7247
    #46
    Thanks HotH2O
    • sailr
      • Nov 2007
      • 6924
      #47
      There ya go! haha
      Originally posted by Diegoboy View Post
      Sailr,
      I intend to be carefull. I will work from an X427 then work up before hitting the stress point.
      Mini Cat Racing USA
      www.minicatracingusa.com
      • ace028
        • Aug 2007
        • 952
        #48
        Deigoboy, this is looking awesome!!!! I can't wait to see more progress, I like your idea about the ply for the hatch to rest on instead of the foam.
        Twin power =
        • Rumdog
          • 6453
          #49
          How's this bad boy coming along?
          • Diegoboy
            Administrator
            • Mar 2007
            • 7247
            #50
            She is in need of a decision (paint scheme) She's easier to paint now than to tape her off later.
            • Rumdog
              • 6453
              #51
              AHHH. True. I bought mine pre-built. I got lucky and she was done right. It's not painted. I kinda like the wood look but, i'm already trying to figure a paint scheme out. Have you had any issue removing the self tapping screws and replacing them?
              • Diegoboy
                Administrator
                • Mar 2007
                • 7247
                #52
                No issues with that.
                • Diegoboy
                  Administrator
                  • Mar 2007
                  • 7247
                  #53
                  1st round of paint... wish me luck.
                  • domwilson
                    • 4405
                    #54
                    Good luck!
                    Government Moto:
                    • Rumdog
                      • 6453
                      #55
                      Are you gonna prime first, or no? Reason i ask is that I just sanded the heck out of mine to paint. Taped it up, primed a sponson, annnnnd the epoxy in a few spots started breaking up. Guess automotive primer wasn't a good choice on my part. Decided to sand off the prime. I think i'll stick with the wood look for now. Did you pick your motor for the stretch yet? If you go with a higher kv are you gonna go with a bigger esc or no? Good luck!!
                      • HOTWATER
                        • 2323
                        #56
                        Ryan, try using spray Kilz first...then sand lightly and then use Krylon primer (2 coats...sanding in between coats) then Krylon spray paint. That combo works really well for me, and I have yet to see any peeling from hatch tape or anywhere else for that matter...
                        -Kent
                        "Will race for cookies!"
                        IMPBA D12
                        • Diegoboy
                          Administrator
                          • Mar 2007
                          • 7247
                          #57
                          I found a can of krylon white primer in the garage. I peeled off all the tape and primered the hull. I can't post a pic because the wife is on the desktop. I will post it later.
                          • Diegoboy
                            Administrator
                            • Mar 2007
                            • 7247
                            #58
                            Primer photo as promised.
                            • Diegoboy
                              Administrator
                              • Mar 2007
                              • 7247
                              #59
                              FYI
                              Yellow krylon doesn't sit well when sprayed over with krylon "fusion" blue. I knew better, but Fusion was the only blue I had.
                              Gotta strip the blue and try again. I hope I don't have to strip the yellow too.
                              • HOTWATER
                                • 2323
                                #60
                                Sorry to hear about that Danny...I've never used Krylon Fusion before...only Automotive Krylon sprayed over Automotive Krylon. Hmmm...it is made for plastics so it must have a different bonding agent that actually sets into the plastic, which the regular Krylon does not mate with very well.
                                Hopefully you can get it cleaned up ok, then try again with the regular Krylon...
                                -Kent
                                IMPBA D12
