Diegoboy's Stretch Renegade rigger
  • Meniscus
    Refuse the box exists!
    • Jul 2008
    • 3222
    Diego,
    I'd spread them out the same percentage as the Matrix, compared to the length I know someone that has one if you need measurements.
    • Diegoboy
      Administrator
      • Mar 2007
      • 7247
      Your green renegade has a sponson spread (outside to outside) of 9"
      My retired renegade has a spread of 10"
      I may go with 10.5" or 11"
      The uncut booms mock fitted to the boat now have a 12" spread
      • Meniscus
        • Jul 2008
        • 3222
        That must be the problem with mine! LOL!
        That's a little sarcasm as I think it was my own operator error.
        What are the measurements inside to inside? Also, at the speeds you're shooting for, have you considered adding a little angle on the ride pads? Might I suggest 2 degree ride pad with the inside edge being lower than the outside? That info came directly from Les.
        As stated, the result would be better tracking in the straights, better turning and less likely to flip while going over more chop. I think you'd be better served to get Dirty to answer his phone. He'd know more than any of us could surmise.
        I hope that helps, not from experience, but from other sources and designs I've seen.
        • Diegoboy
          Administrator
          • Mar 2007
          • 7247
          I wish.
          I'll measure it when I get home.
          • bigpapa
            • Apr 2009
            • 2330
            looks good so far danny.........
            THUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
            CARBON FIBER MINICAT HYDRO,MINICAT HYDRO,PROBOAT MISS GEICO,SKUNKWORKS 32" CAT TWIN, H@M VIPER TURBINE ---JEFF WOHLT WIRE DRIVES
            • sailr
              • Nov 2007
              • 6924
              Cool! I was just gonna ask where you get your carbon fiber plate. Every time I look at it the price is so high I slink back into the shadows!
              Originally posted by Diegoboy View Post
              FYI, that is NOT carbon fiber used for the braces.
              It's merely ply, with carbon decals and a flat black painted edge. (flat was the only black I had on hand)
              Mini Cat Racing USA
              www.minicatracingusa.com
              • Meniscus
                • Jul 2008
                • 3222
                Sailr, how about posting some dimensions of your rigger for Diego?
                • sailr
                  • Nov 2007
                  • 6924
                  You mean the Starship rigger?
                  LENGTH: 420mm
                  WIDTH: 280mm
                  WEIGHT: 357g without receiver and battery
                  MOTOR: water cooled, 20mm x 40mm, 2 pole, 3200KV 64g
                  ESC: water cooled, 3200 KV, 30a continuous, 40A (10 seconds), 6-12 NiMh, 2-3 Lipo, 2A-6V BEC, programmable, 27g
                  SERVO: Mini high performance
                  DRIVE SYSTEM: Flex shaft, 3mm prop shaft, drive dog
                  PROPELLER: Plastic 30mm x 36mm, 4 different diameters available.
                  Mini Cat Racing USA
                  • Diegoboy
                    Administrator
                    • Mar 2007
                    • 7247
                    Those that have renegade riggers will understand this next post.
                    I am still waiting for my LHS to stock up on 1/64 ply. I want to duplicate the top depron section skinned with ply before skinning the provided top ply. The reason is to eliminate the depron lip that the hatch sits on. By this added 1/64 ply skin, the lip that the hatch sits on will now have ply to support it. (so it won't fall apart).
                    • Meniscus
                      • Jul 2008
                      • 3222
                      No, your other personal one
                      Diego, the Michael's by me has some I think I have some 1/32 sitting around if you need it.
                      • sailr
                        • Nov 2007
                        • 6924
                        aha! I'll have to do some measurin'! I didn't build it. Picked it up from somebody else. It's a Climate Matrix. Gonna set it up for 4P. I'm setting up the H&M Xzess Evo II for Spec class with a UL-1 on 4S.
                        Mini Cat Racing USA
                        • 6S HYDRO
                          • 1320
                          yes a ply , hatch lip would be sooo nice, that depron gets so beat up after a while
                          • HOTWATER
                            • 2323
                            Hey Danny!
                            Very cool stretcher you're building!! The length is great...should be a good runner! Is the turn fin support going to be stretched back too? If so, you may want to think about adding a turnbuckle type support that mounts in between the hull and fin...
                            Great job! Keep the pics coming!!
                            -Kent
                            "Will race for cookies!"
                            IMPBA D12
                            • Diegoboy
                              Administrator
                              • Mar 2007
                              • 7247
                              Here's the site I was going to get some CF from. Then I came up with the "immitation" idea
                              • sailr
                                • Nov 2007
                                • 6924
                                Thanks. Dang that stuff is pricey! haha.
                                Mini Cat Racing USA
