boat is wire drive, and if you look the rudder is on the right side, the servo is lined up straight with the rudder ......... see second picture
Intruder s
Why not the steeringrod on the left arm of the rudder, and servo left from the center ?
With a singledrive cat you want as much weight on the left side as possible ?
well ask darin jordan who set up the boat it is very fast and stable in all types of water depending on cog but tks for you adviceTHUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
CARBON FIBER MINICAT HYDRO,MINICAT HYDRO,PROBOAT MISS GEICO,SKUNKWORKS 32" CAT TWIN, H@M VIPER TURBINE ---JEFF WOHLT WIRE DRIVES
i will hopefully this weekend it flew with the bj26 motor cannot wait to test ammo and may put the feigo 12L in it later....... will seeTHUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
Originally posted by Gerwin Brommer View PostWhy not the steeringrod on the left arm of the rudder, and servo left from the center ?
First... for oval racing... I'd prefer the single steering rod to "pull" the rudder, rather than push... especially when having to use a bent-up steering rod.
However, the servo location on this boat was determined by where the steering rod needed to be. That's just where it was when I got the boat from the original builder. It worked fine there originally, and I didn't want to remount all the hardware.
Honestly, I'd prefer to set the hull up balanced down the center, then adjust weight with things that can be moved... but that's just me. As you can see in this picture from when I originally set this up, the servo weight is balanced by the RX weight.
Looks good, Todd... Now... stop tweaking it and start DRIVING IT!
You need to start racing, Dude... ALL of you "Sport Boaters" need to start racing! It'll QUADRUPLE your fun-factor...
Attached FilesDarin E. Jordan - Renton, WA
Darin.
Oval racings. That makes it all cristalclear :-)
As an European i'm not used to oval racing with FE.
It's even worse ! We don't race FE cats in Europe !!!!
I'm glad I could help you out...
Does it give you the goofy grin you have in your avatar, Darin?Originally posted by Darin Jordan View PostYou need to start racing, Dude... ALL of you "Sport Boaters" need to start racing! It'll QUADRUPLE your fun-factor...
"Look good doin' it"
See the fleet
i have driven this boat it just about drives its self very fast and very stable even in a full speed turn....
