The VS1 FE Tunnel hull build
  • cybercrxt
    • 2926
    Well, I had another build thread of my first VS1 (on intlwaters), and this is my new VS1 with some design changes. Its still UL-1 powered with Turnigy 120a speed control. The main differences being the way the radio box is done. I changed it mainly to avoid using so much radio box tape every time I change battery packs! Also, if you look at the steerin cables, I redid my whole thinking on this one. There is an 1/8" brass tube running the length of the steering cable to protect the cable, and protect the batterys from being "filed" by the cable if the battery shifted. Also, I am unveiling my first Epoxy cowling pulled from my mold. I will be using both the Blue/white OEM cowling, and the one I designed. I think it looks pretty cool. Its in primer right now. I will have it finished hopefully by weeks end! Enjoy the pics, Mike
    Video Link:
  • cybercrxt
    • 2926
    • j.m.
      • Jul 2008
      • 847
      Gorgeous.
      Did you chop the tips of the sponsons?
      Or do they come like that?
      • cybercrxt
        • 2926
        Naw, thats the way the VS1 comes.
        Thanks!
        • Norman2
          • Sep 2008
          • 354
          VS-1 Build
          I strongly suggest you use balsa blocks and finish those square pontoons. You will
          never get that shape to handle in turns. See attached photo. Regards
          Norman2
          34" Ekos Cat UL-1 Powered
          • Darin Jordan
            • 9446
            Norman2
            That would be news to those out here that have these FLYING around the course...
            There is absolutly NO issue with these going fast in the turns...
            Darin E. Jordan - Renton, WA
            • Norman2
              • Sep 2008
              • 354
              Vs-1
              Darin, I know you know a lot about hydro and FE boats but I have never seen
              a Formula One boat with such pronounced front square pontoons. See Photo.
              Regards. Norman
              • Norman2
                • Sep 2008
                • 354
                Vs-1
                Sorry forgot photo
                • Rumdog
                  • 6667
                  what does it matter how the sponson tips are shaped when they are not in contact with the water?
                  • cybercrxt
                    • 2926
                    Yeah, ask Grimracer how many national titles he lost with this same hull. What has it won, like 10 titles??? Lol
                    Believe me when I say that video showed me babying it around turns that it can take much much faster if I asked it to!
                      • 9481
                      Norman2
                      That's not need on these boats..
                      • cybercrxt
                        • 2926
                        46mph on radar this weekend. Its running really well! Mike
                        • Darin Jordan
                          • 9446
                          Regards. Norman
                          Would be best not to scale one of these up to full-size then... Likely wouldn't work as well at full-scale...
                          Luckily for us, water and air don't scale, so for our models, and the levels of air-resistance we encounter, these workout just fine.
                          I wouldn't design them that way, as I like the more aero look better, but I doubt that it has much, if any, effect on overall performance. Might even help to keep it from blowing off the water to some degree...
                          • BILL OXIDEAN
                            • Sep 2008
                            • 1561
                            How much do these weigh bare hull?
                            • Darin Jordan
                              • 9446
                              Bill... I'm not sure what the empty weight is, but they are super light when all put together...
                              This is the same hull that Brian just ran in LA for a 2-Lap time of 30.XX seconds, using the UL-1 Motor and ESC, with the ESC cutting out on him... It's a really fast OPC hull, and the price is decent for something like this that comes already built. Just have to fab a radio box for the FE stuff...
