MHZ Micro Shovelnose help...
  • mikesf
    • 96
    Originally a mono freak I have in my hands for the last month a micro shovelnose from MHZ which I got from a friend of mine. After various setups I concluded to this:
    40A Supersimple ESC
    2830 (380S) 2200 inrunner
    1000mAh 11.1 25C Lipo
    2.4GHz receiver
    The shovel runs fine up to 1/2 of the throttle in about an inch wave at a little pond that we have here. It planes quickly, fills up with air and cruises fine. When I try to squeeze the throttle a bit it dives in the water, any ideas how to overcome the problem?
    That's my little pride...
  • Jeff Wohlt
    • 2740
    Are you using a pixtix with that ESC or is it compat with pistol radio?
    www.rcraceboat.com
    jwohlt5362@yahoo.com
    • mikesf
      • 96
      I have a Futaba 3PM 2.4 and it works fine without a pistix, I have though stripped the plastic cover and attached a little brass tube on the plate above the fets to keep it cool. Other than that is it a plug and play ESC, have to set it up for LiPos though...
      • Jeff Wohlt
        • 2740
        Either CG or possible strut angle. Most bury the nose when coming out not the other way. Your prop is obviously pushing the nose in if punching it is doing this while already on top and running.
        Any room to move the CG back a little? Do one thing at a time. At least make sure the strut is flat or has no neg trim in it.
        www.rcraceboat.com
        • bustitup
          • 3072
          what about raising his strut slightly if possible?
          oops i see Jeff suggested that already
          • bustitup
            • 3072
            sweet looking lil shovel man
            do you know what font that is on the lettering...I would like to use that on my "Boogieman build
            40A Supersimple ESC
            2.4GHz receiver
            • Flying Scotsman
              Fast Electric Adict!
              • 5195
              What prop, hardware and do you have a transom photo? A very neat looking boat
              Douggie
              • mikesf
                • 96
                Prop is stock MHZ (29mm i guess), hardware also stock MHZ(.98)... I will post a transom photo, thanks for the good words...
                • mikesf
                  • 96
                  More pics,
                  I have to be straight, the scale details were catered by a ggod friend of mine that deals with mostly scale speedboats. Such a classic hull, if not mahogany planked, it needs some scale details at least the basic stuff...
